Distributor Question
Old Oct 22, 2015 | 08:31 AM
Freemananana's Avatar
Default Distributor Question
I've finally given up on sourcing an OE B16 distributor and decided I'd just buy a crappy Autozone one with a lifetime warranty. Well, there are two options. The TD42u and TD44u. One is much more expensive. I usually just source parts for my B16A with a '95 Del Sol VTEC model, but there are multiple part numbers listed. I think the TD42u is the D16Z6 distributor, but they keep on suggesting it.
Basically, what distributor do I need? I find a bunch of threads asking this, but they never seem to be answered.
Old Oct 22, 2015 | 08:48 AM
whited's Avatar
CRX God
Default Re: Distributor Question
How do you have it wired in right now? I think the wiring and ECU makes the biggest difference. Are you OBD1?
Old Oct 22, 2015 | 08:51 AM
It is OBD1, two connectors. I wish I was running the right distributor. I have a LS distributor on there now.
I've run like 4 different used distributors and they all have a crappy sensor in them.
Old Oct 22, 2015 | 09:04 AM
whited's Avatar
CRX God
Seems like TD42U is for SOHC VTEC
https://honda-tech.com/honda-crx-ef-...td42u-1252134/
Dizzy distributor td41u vs td42u non vtec vs vtec myth busted. - D-series.org
Old Oct 22, 2015 | 10:57 AM
That's kind of what I found. $250 for a distributor it is then.
wwcrxww
Sep 28, 2008 09:52 AM
photec3
Aug 22, 2003 09:06 AM
20lb.teg
Feb 6, 2003 05:30 AM
