Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Eaton charger on 8th gen... help
Old Oct 19, 2015 | 05:02 PM
Mainermatt's Avatar
Default Eaton charger on 8th gen... help
Hey guys new to the site got an 06 civic si I want to fab up an Eaton gm supercharger on it I'm sure someone here has done it and I need advice and information anything helps much appreciated
Old Oct 20, 2015 | 12:25 PM
DaveSi677's Avatar
Default Re: Eaton charger on 8th gen... help
Most ppl are doing the rotrex sc with the Kraftwerk kit being not over the top complicated to install and making way more power... it's not a hard decision to make for the money!
Old Oct 20, 2015 | 02:33 PM
Mainermatt's Avatar
I'm kind of fond of the thought of my own setup though knowing everything about it not fond of dishing out 5k on kraft works either
Old Oct 20, 2015 | 08:30 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You need to create an intake manifold, create a drive system, and create an intercooler path so that you can safely utilize the Eaton Supercharger, oh and you will need to purchase a FlashPro, fuel injectors, a MAP sensor and a fuel pump... then you have made a one-off kit that likely isn't as good as the Kraftwerks kit mentioned above... and you saved SOME money.
Good luck.
Old Oct 21, 2015 | 06:54 AM
DaveSi677's Avatar
Probably won't save that much money considering he will need to create a drive system and a few other things... all that R&D needs to be accounted for lol
Old Oct 26, 2015 | 04:33 AM
tony_2018's Avatar
Fish Twig
intake manifold has to be modified, pulley system designed. Getting a used supercharger? Get it maintain by replacing bearings, new fluids, new solenoid, the works. The bulk of the work is "designing" the layout for a supercharger that wasn't meant for the car.
justinwazner
Jan 21, 2011 09:15 AM
Nicks95GSR
Oct 15, 2007 12:55 PM
Benjithx
Jun 12, 2004 06:48 AM
sivik2nr
Jan 28, 2002 09:48 AM
