Low idle even on cold start
Old Oct 18, 2015 | 08:55 PM
heinrichranches's Avatar
Default Low idle even on cold start
Hey Honda-tech!
I have this issue for a long time already. On cold start, idle is around 500-600rpm only which should be around 1.5k on cold start. Then on a short drive idle turns to 1.5k rpm on idle. What I do is shut off the engine and restart. Then idle goes back to 500-600rpm only.
What we did already is pull down IACV and Throttle Body then clean but nothing changed.
Note: Had an issue already before on the throttle body coolant passages. (coolant leak specifically) but we had it repaired already.
Thinking of getting a new tbody already.
Car is on Stock P2T ECU. Can anyone help?
Car is 1999 Honda Civic SiR EK4 (B16A2) sedan from the Philippines
Thanks
Old Oct 18, 2015 | 09:01 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Low idle even on cold start
https://honda-tech.com/honda-civic-d...sting-3002401/
We shouldn't have to make assumptions or guesses. Basic information (ya know, like what car you have) is required for a reason.
Old Oct 18, 2015 | 09:12 PM
Sorry about that, my car is a 1999 Honda Civic SiR EK4 Sedan from the Philippines. B16A2.
Old Oct 19, 2015 | 12:47 AM
Couchwarrior's Avatar
Maybe the fast thermo idle valve?
Old Oct 19, 2015 | 06:50 PM
Thanks for the response. Haven't checked the FTIV yet. But I ordered a Type R throttle body instead.
Old Oct 19, 2015 | 07:39 PM
NotARaCist's Avatar
Please, show us where the FITV is on a stock 99-00 SI. I dare you.
Hint: Honda did away with the FITV in '96.
OP, is your CEL on? Does it work? The Type R TB is not going to do anything for you - don't waste your time.
Old Oct 19, 2015 | 08:57 PM
Got a Throttle body that has a new FITV.
CEL is not on nor flashing in some rpms.
95Sedan
Oct 11, 2013 03:29 PM
Da9austinRacing
Mar 19, 2011 07:42 AM
ricknbird350
Aug 24, 2007 06:12 AM
94dxt
Aug 14, 2003 09:03 PM
