Ovearheating and overflowing radiator
Old Oct 17, 2015 | 04:48 AM
unleashed civic's Avatar
Default Ovearheating and overflowing radiator
Hi guys,
I have read most of the topics, but can't find a solution to my problem.
So I have a d16y7 engine with D16y8 head JRSC @ 7psi
If I drive normal, under 4k rpm, maximum half throttle, no problem.
When I floor it the engine overheats after about 10 minutes (not even flooring it 10 minutes, just 2-3 pulls)
Radiator overflows, and so does my overflow tank.
What have I done/changed:
-Tried 2 radiators, single slot, and dual tucked
-New race thermostat
-New head gasket
-New radiator cap
-Double fans
-Fan override, so it turns on when the car turns on. (it didn't overheat so fast)
Does anyone have a clue what my problem could be? :S
Since I have a d16y7 I dont have a bleed nipple, so before every test,
I let the engine get warm with the radiator cap off, and fill the system when needed.
Thanks!
Old Oct 17, 2015 | 09:01 AM
civic-steve-94's Avatar
Default Re: Ovearheating and overflowing radiator
You don't need a "racing thermostat" oem works just fine. Does your heater work good? If not your water pump isn't flowing. What coolant mixture are you using? When its overflowing that means it is boiling which when coolant is mixed right is at like 245 degrees. When you did your head gasket did you take your head to a machine shop to have it check for warpage?
Old Oct 17, 2015 | 04:03 PM
holmesnmanny's Avatar
Compression test to see if you are shooting combustion gases into the coolant.
Old Oct 17, 2015 | 09:44 PM
Oh I forgot chemical block test kit
92civicx
10
Sep 3, 2007 07:07 PM
HiMilerCivic
11
Apr 19, 2005 07:17 PM
sleepyhamsterlx
10
Feb 1, 2004 12:48 PM
CroSi
Oct 22, 2003 04:24 AM
yoshe95si
Dec 25, 2001 05:22 PM
