Hondata CEL 11
Old Oct 16, 2015 | 04:02 PM
ramboPandA's Avatar
Default Hondata CEL 11
Hey can someone point me in the right direction. I have a Hondata and got a CEL 11 while driving. Pulled over turned off the car completely, turned it on and drove home no CEL came back. I have a OBD2 to OBD 1 Harness, could a connector be lose, or is my ECT bad?
Has not given me this problem before. I drove during the summer when it was Hot outside and no CEL for code 11. Fan is working, coolant right level also. Motor is rebuilt few months ago, with an OEM water pump, so i know its not that.
Any clues?
TY
Old Oct 16, 2015 | 09:33 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Hondata CEL 11
Any clues?
TY
There is no obd1 code # 11,
If you receive the OBD-I code 11, then there is something wrong with your Electronic Control Module (ECM). The ECM is a type of embedded system that manages you electrical systems. An embedded system is a type of computer system that is designed to do only one (or a few) functions, such as control your electrical system. You should run tests on this system to determine whether it is not working properly or if it has failed. You can also try refreshing or updating the system to see if that clears the problem. The Code 0 (zero) is also associated with ECM errors.
TB123
Engine Management and Tuning
Oct 27, 2012 11:45 AM
95BG33PGSR
Dec 28, 2011 08:35 AM
steven_highet
Jul 24, 2009 09:46 AM
ls19integra95
Mar 19, 2008 01:13 PM
CubanLynx84
May 7, 2007 11:54 AM
