2000 gsr multi cylinder missfire
That doesn't mean the crank is out of time. There are more marks for your timing than just the cams. Pull the timing covers off and check all of them. Are you using new plug wires? Did you put a new or used Honda dizzy on or did you buy a reman dizzy?
If you had an issue with your valves, you wouldn't be blowing 210 across all cylinders. How do you set timing on your distributor when the engine is misfiring?
i just recently had the same problem today with all four of my cylinders i checked the spark plug gaps on my NGKS i adjusted them to 1.1MM because i saw they were going a little black i was running rich so i took the oxygen sensory B1S1 that goes on the header was black replaced that Changed my Dizzy to a brand new one and i checked the IAC valve cleaned it because it was having a very rough idle think about it if you don't have the correct air ratio going into the motor then your not going to have the right fuel ratio and ftwwwww
CivicSmith
42
Jul 8, 2014 12:54 PM
