any specific reason for knock at 7000 rpm?
Old Oct 14, 2015 | 03:51 PM
blackeg's Avatar
Default any specific reason for knock at 7000 rpm?
the last 2 setups ive had in my eg have had activity on the knock sensor at 7000+ rpm. one setup was moderate compression all motor lsvtec, the other a 84.5x89mm boost motor. the tunes were not based off one another in any way. the tune on the boost motor worked with no knock last year. it was re ringed over the summer and has appropriate compression and leakdown. this motor is currently in the car
ive tried varying the timing by a few degrees as well as running richer or leaner. all pretty much yielded the same result. just wondering if there was something else i may be missing over or if it is just in the tune
Old Oct 14, 2015 | 07:59 PM
turbohatch96y7's Avatar
Maybe you arent hearing knock?
What do the plugs look like?
Old Oct 15, 2015 | 03:18 AM
blackeg's Avatar
Default Re: any specific reason for knock at 7000 rpm?
little bit of black specs no silver. I can see where the carbon flaked off the top of the piston through the plug hole. once it starts knocking I let off as quickly as I can. color change is on the bend but its different shades of gold no real blue. my egt also reads quite cold im waiting for a new fitting to exyrnd the probe into the runner more see if it changes anything
Old Oct 15, 2015 | 07:15 PM
Muckman's Avatar
Moderator in Chief
Generally if you remove a large amount of timing, add fuel and it still knocks then its not detonation but most likely mechanical noise. Its very important to baseline your knock sensor NA or very low boost with a known safe tune.
Old Oct 18, 2015 | 10:58 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Are you sure your fuel pump/filter/lines can provide adequate flow and pressure, or could you be maxing it out at WOT and high revs?
Old Oct 18, 2015 | 03:48 PM
blackeg's Avatar
fuel system is good, ive had it the same for the last few years making 440+whp, 16psi on a 60-1. this just 13 psi on a 57 trim for the time being. im also going to try a different gas station. this sunoco i feel is getting sketchy next fill im going to a mobil across town
Old Nov 15, 2015 | 03:42 PM
VegasInvasion's Avatar
I'm Huge In Japan
high combustion temp. try a colder plug, larger gap, or lower thermostat.
CaliforniaDad
Mar 14, 2016 04:45 PM
P-ville
Jul 29, 2010 06:01 AM
bdavis
Mar 28, 2006 12:18 PM
sshaikh01
Feb 8, 2002 08:32 AM
