So I just put a fully built 97 gsr head port and polish with skunk2 tunner 2 cams reteiner keepers super tech flat valves double springs black aem cam gear big b17 VTEC solenoid on a stock bottom 95 GSR block.
Now my question is this
We did a valve adjustment and they still sounds lose
If its regarding your valves sounding loose after adjustment, they were either adjusted incorrectly or something else within the build wasn't correctly done. If you did this build using parts that had mileage on them, you should check to make sure they are all within specs and not worn out.
