Eg hatch brake lights and turn signal don't work?
My brake lights doesn't work any more, my turn signal doesn't work. When I turn on the headlights, the passenger turn signal lights up in the rear and on my cluster. I swap the entire chassis harness off my old shell which is known to work, and still the same thing.
Ok I found the problem on mine, the tail light harness big plug that plugs into the big plug for the chassis harness was not in the same pins. I had to re-pin it. Its the plug that sits at the rear driver quarter panel.
Apr 2, 2003 06:33 AM
