Re-use JDM Harness??
So I'm sure this question has been asked before but I decided to ask anyway:
I've got a 2001 Integra LS that I'm putting a 98 JDM ITR motor in. My question is pretty straight forward. Can I re-use the JDM harness? I know there are a few plugs that are on the opposite side but I plan on taking the harness apart and re-routing everything. I know it'll be a lengthy process but I got the time.
I've done a JDM swap before in an LS and used my LS harness last time, but since I have the JDM motor out I was hoping to just use the JDM harness.
If it can't be done I'm OK with that. It means I'm just going to have to use the LS harness.
I mean if you take it apart and reroute I don't see why you couldn't. The only issue I foresee is if you ever have to use a USDM ECU for emissions purposes you'll need to bypass and add some sensors.
highroller54
Feb 13, 2007 08:29 PM
