Toe in or toe out when raising with coil over?
Old Oct 8, 2015 | 03:24 PM
maxogsr's Avatar
Default Toe in or toe out when raising with coil over?
I ll have to raise my car to tow it
Last edited by maxogsr; Oct 10, 2015 at 03:49 AM. Reason: No anwser here... I have create a new tread where i think i will have more answers. Can t find a way to delete it
Old Oct 9, 2015 | 07:55 AM
Tight-R's Avatar
Default Re: Toe in or toe out when raising with coil over?
I can imagine the tie rod is at an upward angle since the car is lowered, so if you raise it up the tie rod will essentially move back to a more level position, which I *think* will toe the wheels OUT.
I could be completely opposite on that though, I have no idea what angle (up or down) the tie rod is at when the car is lowered. I've never really looked if I'm honest.
Either way, if you're changing the suspension geometry, just get an alignment done.
Old Oct 10, 2015 | 09:52 PM
Garage_Spec's Avatar
It will toe out. Just take a precise ride height measurement on every corner and lower it back down after the tow. It should still be aligned.
OmarR
Suspension & Brakes
Aug 13, 2008 12:14 PM
busyychild
Jan 3, 2008 01:30 PM
Halo
12
Jun 10, 2005 03:42 PM
suspendedHatch
Nov 24, 2004 10:15 AM
RineRacing
May 8, 2002 06:31 AM
