headgasket leak pics
Old Oct 8, 2015 | 12:06 PM
joytjuhhhh's Avatar
Default headgasket leak pics
i had bubbles and presure in the rad.
no oil or coolant mixing and no white smoke.
removed the head
i think it leaked at the 3 cylinder into the coolant chamber
what do you guys think?
did i cleaned the block surface good?
in the front left corner there is some dirt that would come of.
it leaked oil before in that corner
i steelbrushed it and sanded it a little but i dont want low spots
the head is millend today
Old Oct 8, 2015 | 06:39 PM
Bently_Coop's Avatar
Steve at Heart
Default Re: headgasket leak pics
Is the block surface flat? '
You need a straight edge and feeler gauges to check this. Something like in the link below.
Tricks of the Trade: Cylinder Head Distortion Check - Import Tuner Magazine
Old Oct 8, 2015 | 10:12 PM
joytjuhhhh's Avatar
i didnt checked that yet.
do you see something wrong on the clean up picture?
i did have the head surfaced but it wasnt warped .
thnx
Old Oct 9, 2015 | 01:54 AM
king06's Avatar
Did you do a compression test or a leak down?
Pressure and bubbles in the rad doesn't mean you have a bad head gasket.
Old Oct 9, 2015 | 12:54 PM
joytjuhhhh's Avatar
no didnt do a leak down or compresion test.
there could be 2 ways air getting into the coolant.
changed the thermostat,rad and hoses and bleed it for 2 hours.
but stil huge bubbles comming out of the rad.
thnx for you reply
Old Oct 9, 2015 | 07:55 PM
holmesnmanny's Avatar
When the head overheats it's not just the gasket that goes bad, the head is permanently warped. It either needs to be put in an oven at 500 for some time in between two straight pieces of metal or you need to resurface it. Simply replacing the gasket and cleaning up the surface won't accomplish anything.
You also need to check the block as the above poster said to determine if the block got warped which is more rare but not unheard of.
Old Oct 9, 2015 | 07:58 PM
hondamike42's Avatar
ONE TIME I DID A HEAD GASKET ON THAT ENGINE AND IT ENDED UP HAVING A LOWER ENGINE BEARING PISTON PROBLEM, THE ENGINE TURNED SMOOTHLY WITH HEAD OFF, IT WAS STRANGE i NEVER FIGURED OUT WHAT WAS WRONG WITH ENGINE,
Old Oct 10, 2015 | 02:48 PM
YOU CAN CHECK WITH A METAL RULER AND FLASHLIGHT AND SMALL FEELER GAUGES
Old Oct 10, 2015 | 02:53 PM
EXCUSE ME, I RECENTLY JOINED THIS SITE, COULD YOU PLEASE ADD ME AS A FREIND AND EXPLAIN HOW I CAN WRITE A POST? ALLS i CAN FIGURE OUT IS HOW TO REPLY THANK YOU - MIKE
Old Oct 10, 2015 | 10:20 PM
king06's Avatar
thnx for you reply
The times I've had blown head gaskets there's liquid on at least one cylinder, that's how I've know I had a bad gasket. The surface looks great after you cleaned it so you did a great job at that.
Last gasket I did was a single cam with the oem "cardboard" gasket, all I did was clean it the best I could and slapped it back together. For me, as long as it doesn't over heat too bad the head should not be warped. I've done two sohc like this and they are both running strong since, and its been a couple of years.
Also, you CANNOT check for straightness with a regular metal ruler.
Old Oct 12, 2015 | 04:15 AM
joytjuhhhh's Avatar
thnx guys.
i did surfaced the head.
but i didnt surfaced the block bottom
last night i replaced the gasket.
today or tomorow im going to test it
Old Oct 13, 2015 | 01:07 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Not really. It depends more on how long it was driven hot. A head can take a lot of heat before it actually warps. Casting temps on the head are pretty high to begin with.
Old Oct 13, 2015 | 01:10 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
removed the head
How did you clean the surface? Sand paper? No,no!It should be as smooth as glass with no roughness to it. So should the head, other wise the headgasket will leak again.
Old Oct 13, 2015 | 09:21 PM
If the gasket leaks then the head is warped and/or the block is warped.
The gasket will never leak without the above. That's the reason it leaked in the first place. This assumes the head has never been pulled.
Old Oct 14, 2015 | 10:29 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
This is completely false.
Such a moron,I dont know why I always bother with you.
Old Oct 14, 2015 | 11:31 AM
joytjuhhhh's Avatar
the surface i cleaned with brake cleaner and clothing.
i sanded it 2 or 3 strokes in the right front corner because it was dirty there alot.
i coulnd hurt sanding it 2 a 3 strokes there
you should look at the bevore and afther picture,the dirt is stil there.
Old Oct 14, 2015 | 12:52 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
As long as the surface is smooth. Despite the moronic opinion that the head gaskets only leak when there is warpage,that is rarely the case.
MLS gaskets conform well to slight variations in head and block surfaces,however the coating on the gasket must remain intact. This coating(looks like black/blue paint) is a major part of the headgaskets sealing properties.
MLS gaskets rarely break,instead the coating erodes and comes off over time or in the event of overheating,typically at the cylinder sealing rings.
But if the surfaces of the block and head are rough,they will prematurley damage the HG during contraction and expansion.
Make sure the surface is a smooth as possible.
Old Oct 14, 2015 | 04:03 PM
hybridmiklo's Avatar
You really need to straight edge the block. Dont know how many clowns over here dont do that end up with the same issue. Dont forget to check the head as well with the straight edge. Looks like it was leaking into both cyl 2 and 3. A good indication is how clean the pistons are. Also, I personally do not reuse headbolts.
Old Oct 15, 2015 | 10:39 AM
turbohatch96y7's Avatar
Ive used a 2x4 and some sand paper. Maybe 200 grit and stroke even across the block and you can see if there is a low spot or hight spot.
Not on heads tho. Those go to the machine shop
Its not the right way to do it but if you dont want to drop 150 bucks for a precision flat bar then itll work
Ive never had a gasket blow on me. Ive cracked sleeves pistons rods
Never a gasket
Old Oct 21, 2015 | 03:11 AM
joytjuhhhh's Avatar
yesterday started the car
i tried to bleed the car for an hour but stil tiny bubbels come out.
the fan kicked in like 5 times.
the bubbles are not like before i replaced the headgasket.
before there where big bubbles and these are tiny bubbels.
car didnt overheat ,car gets hot inside,no oil or coolant mixing.
doesnt drips oil between the block en head anymore
also the car smoked a little white\grey smoke but that could be because of the weather here.
and i cleaned the engine bay with water ,and sprayed some water into the testpipe
Timing belt and valve clearence are good.
thortle cable and dynamo and ps pump belt are to thight.
i have to fix this when im home.
engine also ticking at the front i think i have to adjust the ignition.
(or maybe thight belts)
also the exhaust sounds different.(not a misfiring sound)
so maybe a dizzy or idle issue
i did make marks when i removed id.
do you guys think its the gasket or do i have to bleed it more ?
also i replaced my old big heavy rad for the oem dxi (eg4) rad .
i have tested it with water to see if its not clogged.
but i dont think the test is good this way.
what could cause air into the coolant exept a failed headgasket
-i clamed the **** out to let the b serie hoses fit on the d serie oem rad
-could the Heather core causing problems ? ( no leaks seen)
Old Oct 21, 2015 | 09:40 PM
Me neither. You always lose.
Old Oct 21, 2015 | 09:42 PM
lol I really don't understand where you get this stuff.
Why would you possibly think that head gaskets leak just because. Can you do a magic spell on a head gasket and make it leak too ?
A head gasket will outlast an engine, as long as the car never ever overheats. You should know this. But I'm not surprised you don't since a lot of your opinions are so hilarious.
Old Oct 22, 2015 | 08:16 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
18 years as a professional mechanic, 100s of hours of training in the automotive field.
What exactly is your experience?
I dont.
Wrong.
Old Oct 23, 2015 | 06:26 PM
If I told you I have 10 years experience with Hondas/Acuras why would that have any bearing on this thread discussion if I'm right ?
If I told you I have no experience whatsoever working with Hondas/Acuras why would that have any bearing on this thread discussion if I'm right ?
Perhaps your experience itself will help you win an argument when you're wrong.
I'm not always right, but atleast I admit it when I am wrong. I really think you misread what I originally said. But you can't go back and say it cause you have too much pride.
Old Oct 24, 2015 | 08:17 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
So the ambiguous, "maybe I do,and maybe I dont"? In a nutshell you have no clue what youre talking about.
I thought so,it was obvious......
