starter clicks but dosnt turn over
Old Oct 7, 2015 | 06:10 PM
sandman444's Avatar
Default starter clicks but dosnt turn over
I just took out the engine and put a few new gaskets in, now its back in and wont restart. The clutch is in and the starter will click but wont turn over, the check engine light is also on but I don't have a reader. The batterys good and ive charged it multiple times, all connectors to starter good, I cant imagine it would be the solenoid, so what could it be? anybody have a guess on what the code is?
Old Oct 7, 2015 | 06:17 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: starter clicks but dosnt turn over
OK, let's go down the list.
First off, the rules are not optional. Read them, and fill in the required information.
https://honda-tech.com/honda-civic-d...sting-3002401/
Second off, you don't need a code reader to pull codes.
https://honda-tech.com/honda-civic-d...lists-1901557/
Third off, are you having a no-crank no-start, or a crank no-start? It sounds like you're having a no-crank no-start, but we need to be sure before we spend time diagnosing something that isn't your problem.
Old Oct 7, 2015 | 06:55 PM
Jimi Hondrix's Avatar
First things to check is: battery, starter solenoid and starter. Find a youtube video on how to diagnose a starter..there all the same basically so it doesn't have to be Honda specific.
If you're feeling gun-ho then remove your starter (solenoid attached) and battery and bring them in to Autozone for free testing.
Old Oct 8, 2015 | 12:35 AM
eghatch9295's Avatar
Stancetard Hate Monger
no, hoss. on an engine reinstall with a no crank no start condition, first thing to check are grounds. even with any cel problem, the engine will still crank.
Old Oct 8, 2015 | 01:02 PM
I guess I should have read through the OP's entire post instead of just the title..lol
darkstormcr
May 12, 2014 10:31 PM
Ryan559
Mar 22, 2011 05:53 PM
slammedtegls
Sep 24, 2004 07:05 AM
1990hondaHF
25
Nov 9, 2002 12:20 PM
