Repeating starter failures
I have a '93 with a OBD1 GSR motor. It gets seldom use, only for track days every 2-3 months or so.
Anyways, having issues with the starting system. I have run into the same issue on two working starters. IMO I have had very few issues with starters so I don't think the actual starter itself is the issue.
I can start the car once on a good starter, run it until warm, drive it around etc., and then turn it off. When I go to start the car next time, regardless of warm/cold:
- All lights illuminate
- Fuel pump primes
- MIL light on/off (no code)
- Fuses OK
- Battery is 12V
But, when I move the key to crank, I just get a fast clicking noise but no movement in the engine at all.
Any ideas on where to look first?
- Fuel pump primes
- Fuses OK
- Battery is 12V
Re: Repeating starter failures
Swapped the starter for a known good one. It fired up on the first turn after install. Then I let it sit for a few hours, went back to start it and that's when I experienced the fast clicking.
Have also checked the battery voltage and terminal connections and they were OK.
Jack Murphy
06-21-2017 06:23 PM
