Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
03 LX, replacing stock D17A1 with stock D17A1 - out the bottom?
Old Oct 4, 2015 | 09:10 AM
ScottRussell's Avatar
Default 03 LX, replacing stock D17A1 with stock D17A1 - out the bottom?
I have a lift, just haven't ever done a FWD car before. My 03 Civic LX 5spd is all stock and I'm putting it back all stock. It's my daily driver and I commute 175 miles per day. The car has 332K miles on it, but is in near perfect condition other than the engine, so I really don't want to replace it.
I bought a low miles D17A1 and I have it stripped off the parts that won't be used, and it's cleaned up and ready to go in. However, I had originally thought of pulling the engine out the top, but from what little I've found on the subject, it appears the easy way is out the bottom.
As I mentioned, I do have a 2 post lift, just wondering if I need to drop the engine out the bottom, or pull it out the top. I'll also be replacing the clutch while I've got the engine out, as the clutch is still the OE.
Any tech advice is appreciated.
Old Oct 4, 2015 | 06:09 PM
lazlong's Avatar
Default Re: 03 LX, replacing stock D17A1 with stock D17A1 - out the bottom?
If you have a lift it's much easier to go out the bottom. Support the engine/trans with your tranny jack then drop the sub-frame down around it. You'll have to step around the sub-frame after that. Good luck and post up how it went.
Old Oct 4, 2015 | 06:23 PM
slowDB7's Avatar
When i did my swap, i went out the top with a engine hoist seemed alot easier then having to drop the subframe.
Old Oct 4, 2015 | 06:47 PM
lazlong's Avatar
If it's dropping the sub-frame vs moving all that crap again I'll go with dropping the sub-frame every time.
Old Oct 5, 2015 | 01:26 AM
slowDB7's Avatar
All i moved was power steering lines, shiftlinkage, clutch line and wire harness
Old Oct 5, 2015 | 06:27 AM
Thanks, will do.
Old Oct 5, 2015 | 06:32 AM
I looked at it at length yesterday with it on the lift. Going out the bottom does seem infinitely easier. Just 4 bolts, take loose the struts from the spindles, remove the brake calipers, and after disconnecting everything from the engine and trans, the entire engines/trans assembly drops out without even removing the CV axles. Looks super easy.
I'll take pictures as I go and post after next weekend.
Old Oct 5, 2015 | 07:53 AM
slowDB7's Avatar
Man i need to get a lift sometime
Old Oct 6, 2015 | 08:59 AM
car5car's Avatar
$900 new.
Old Oct 6, 2015 | 10:37 AM
slowDB7's Avatar
From where
MikeB20v
Transmission & Drivetrain
Jul 30, 2013 11:11 PM
ninjarico
Dec 11, 2005 06:36 PM
JDM00SI
Nov 13, 2004 01:49 PM
Chiovnidca
Oct 20, 2002 06:06 AM
