Air compressors?
Looking to purchase a 60gal air compressor. I have kind of narrowed it down to these 2:
Ingersoll-Rand SS5L5
Quincy QT-54
Comparing 2 Items | Northern Tool + Equipment
Both are 230V, 2-stage, 1-phase compressors.
The quincy has 175 max psi, IR has 135 max psi
quincy has about 15.5 cfm at 90 psi
IR has about 18 cfm at 90psi
quincy is 1400
IR is 980
The quincy has a baldor motor, which is about the best you can get. Both have similar warranties.
Just not sure if the 175 max psi of the quincy outweighs the 3 extra cfm at 90psi of the IR...and 400 dollars cheaper?
thank you
Quincy QT-54
quincy is 1400
IR is 980
thank you
Actually IR compressors have really fallen off, same with their impacts. I use 3/4" and 1" impacts every day, and it's sad when you are reaching for the Chicago Pneumatic instead of the IR...
It depends on what you need the compressor for. If you need 150 psi+ on tap (which can definitely make the difference between removing a bolt or not) Between the two choices, I would definitely look into the Quincy personally. The last IR we had lasted until just outside it's warranty.
ek96vtec
Paint and Body
45
Apr 27, 2009 10:51 PM
Be sure to update later down the road if you remember to!
