Feul Preasure questions
What is it stock? What PSI are you running at, with what mods?
I installed mine and the PSI was at 42 durring idle with no adjustments to the regulator. Most everyone I talked to said that on a stock R to turn it UP to 38, maybe 40. Do you think that mine came from the factory a little rich? Would this explain why my R dynoed so low (157)?
[Modified by Junglist, 5:26 PM 11/5/2002]
I must be talking about something else...
I have the B&M Feul Preasure Regulator and the Feul Preasure Gauge.
http://inlinefour.com/bmcommandflo.html
http://inlinefour.com/bmfuelpresga.html
was the fuel pressure regulator pre set before you put it on or was it as low as it can go and i would sugest a air fuel ratio gage too if you wanna do it your self but i would set around 35 psi and go from there
