jdm b16a sir2 - need help finding parts
Hello I recently just purchased a 1992 honda civic si and the engine was swapped with a b16a sir2. I was looking up what cars this engine comes from but there all jdm aka honda integra isx and honda del la solution sir and when I look up parts online to buy I can't search with those model cars cause they don't recognize them. Basically what car can I enter so I can get the correct parts without having to have such a hassle in finding the correct parts. Thanks
Generally speaking OBD version will be the biggest factor, having said that you'll probably be just fine with the Del Sol Si VTEC model since it uses the B16A3 (not "del la solution sir" LOL) if you're in the states. Mechanically speaking almost all of them share the same general parts/seals/gaskets. Can you confirm which OBD or at least ECU your car is using?
bagged89hatch
Jun 19, 2003 11:03 PM
MugenHonda
Aug 12, 2002 09:03 AM
