Oil line and can needed on b18c5
Old Sep 29, 2015 | 11:24 AM
Krazy613's Avatar
Default Oil line and can needed on b18c5
Just swapped from b20v to b18c5. Do I need a catch can. Or the tap that was to the head from the oil pressure switch ???? Thank you
Old Sep 29, 2015 | 01:27 PM
B_Swapped93's Avatar
Default Re: Oil line and can needed on b18c5
No you don't need either, only reason for the line is due to it being a hybrid/frank set up as there was never a 2.0l vtec b series from the factory that's all.
Old Sep 30, 2015 | 07:46 AM
Krazy613's Avatar
Hey thanks so much for the reply. All I know is integras b series lol. But I wasn't sure since I never did a b20v swap. But been figuring it out last year. But my b18c5 I bought off kijiji the guy was building for turbo. Cp low comp pistons eagle rods new gaskets everywhere arp studs head and main and block and head machined. All I know about it. And now 2 weeks of driving on a tune for the b20 the head gasket seeps very lil oil under the cam seal corner front left looking at it. Just wonder if it's the pcv system or the arp studs witch were already put together when I bought it
Old Sep 30, 2015 | 02:57 PM
wunfstgsr's Avatar
Loved
Community Favorite
prolly the cam seal leaking or distributor o ring leaking or valve cover gasket leaking..
Old Sep 30, 2015 | 08:35 PM
tony_2018's Avatar
Fish Twig
pcv system runs in the back of the block, clean off any oil stains and locate the leak.
Old Oct 6, 2015 | 06:28 AM
Krazy613's Avatar
Hey yeah it's right from the corner of the head gasket by the cam seal. I think they didn't tourqe the arp head studs properly. I still never hit 8k 7.5 couple times now mostly only to7.
bks84
Apr 18, 2009 04:04 PM
tazzsi84
21
Mar 7, 2009 05:24 PM
civicb16eg
Jun 24, 2007 08:57 PM
Redsun
Mar 22, 2005 06:17 AM
Ri5e
Apr 3, 2003 09:55 AM
