2000 honda civic vp
Old Sep 24, 2015 | 01:49 PM
wheelchair's Avatar
Default 2000 honda civic vp
hello every one
i have had my Honda for about a mouth and in the morning it startes up no problem at all but when i get out od school or have to run in the store real quick the car will not want to run it will just sit there and crank over and over. some time if i jut wait it may start up again. i checked the it is getting fuel and air and it does have spark. other than this i have no idea what is going on with my car and anyone help me out? that would be great thank you.
Old Sep 24, 2015 | 01:53 PM
LearnOrGetBurnt's Avatar
Default Re: 2000 honda civic vp
do you have to get jumps? check your battery. That's where I would start.
Old Sep 24, 2015 | 01:59 PM
wheelchair's Avatar
no i do not and i have checked the battary
Old Sep 24, 2015 | 02:00 PM
Because if you're getting spark that rules out your ignition coil.... either battery or starter.
Old Sep 24, 2015 | 02:01 PM
wheelchair's Avatar
its is neather of them
Old Sep 24, 2015 | 02:02 PM
NotARaCist's Avatar
I never narc'd on nobody!
Did you check your fuel and spark when it wasn't starting? It's very nearly always one of two things, but figuring out which one involves testing when the car won't start.
When the car won't start, turn the car completely off. Remove the key. Put the key back in, and turn it to ON(II). Does the CEL come on for ~3 seconds, then turn off? Do you hear the fuel pump priming?
When the car won't start, test your spark. What color is it? "I have spark" is diagnostically useless.
No, it doesn't.
Old Sep 24, 2015 | 02:04 PM
wheelchair's Avatar
i can hear the fuel pump
Old Sep 24, 2015 | 02:05 PM
If you had the battery checked I suppose the alternator was checked too right?
Old Sep 24, 2015 | 02:20 PM
NotARaCist's Avatar
When the car won't start, do you hear the fuel pump, and does the CEL work? Multiple questions have been asked. If you can't answer them all, we won't be able to help you diagnose.
Old Sep 24, 2015 | 08:24 PM
Jimi Hondrix's Avatar
Read this: 1999 Civic DX hot start problem - Honda Civic Forum
vickyphan
Honda Civic (2006 - 2015)
May 25, 2015 12:07 PM
CaseyB
Nov 16, 2012 06:03 AM
AKprelude
Nov 12, 2004 02:24 PM
posterchild
Jun 26, 2004 02:09 PM
Audio28
Jul 3, 2003 05:33 PM
