GSR not starting after rebuild
Old Sep 22, 2015 | 03:57 AM
stavri's Avatar
Default GSR not starting after rebuild
I just rebuilt my 2001 B18C integra gsr. It was miss firing on cylinder 1 &3. Turned out to be a burnt and cracked exhaust valve on #1. After putting engine back in it started, reved fine,but was running rough at idle (going up and down)and sounded like a misfire. the CEL codes showed (5) misses on all 4 and all missfire. I rechecked and adjusted the cams slightly according to the workshop manual.Now it wont start. I checked the all functions in the distributor and all checked out. If i take #1 plug out and crank the engine grounding the plug i get a few sparks then no sparks. Its that normal? All cars I usually work on have limited electonics on them and will fire a spark continiously.The only other variable I changed was I bought a used knock sensor as I broke the original taking the motor out. I assume if this was bad it would not cause the motor to not start. Any other ideas. This is a real pain after spending all that time on the rebuild. BTW-It has all stock parts in it.
Old Sep 22, 2015 | 03:57 PM
hondalocal's Avatar
10 Year Member
Default Re: GSR not starting after rebuild
Check the position of the spark plugs on the dizzy. First time I rebuilt my motor I had them all mixed up.
Probably too simplistic, but worth a shot.
Old Sep 22, 2015 | 03:58 PM
hondalocal's Avatar
10 Year Member
Check the position of the spark plug wires on the dizzy. Happened to me on my first build.
Old Sep 22, 2015 | 06:07 PM
stavri's Avatar
I wish it was that simple. The dizzy cap and wires were new so I didn't touch them from before the rebuild. All set up correctly. I wish someone can tell me why I don't get a constant spark at the plug when testing it.
Old Sep 23, 2015 | 10:20 AM
PR8urVtec's Avatar
Make sure ALL of the grounds are clean and tight. Grounds can do crazy things.
What else have you tried? You found that the spark is the problem. Start checking everything associated.
So you have raw fuel on your spark plugs?
Crank position sensor hooked up?
Old Sep 23, 2015 | 04:31 PM
stavri's Avatar
I have no spark at the plugs. Checked all internal distributor functions and the check out. Checked all fuses. No fuel on plugs.
Checked all grounds. What else would cause no spark?
Old Sep 23, 2015 | 05:46 PM
wunfstgsr's Avatar
Loved
Community Favorite
test the coil in the distributor
Old Sep 23, 2015 | 05:55 PM
stavri's Avatar
Coil is fine.
Old Sep 23, 2015 | 06:01 PM
wunfstgsr's Avatar
Loved
Community Favorite
Originally Posted by stavri
Coil is fine.
Did you test the resistance in the voltage with a multi meter? if your getting spark at the coil, then its either the rotor or wires.
Maybe you put the distributor 180 deg out
Old Sep 23, 2015 | 06:28 PM
PR8urVtec's Avatar
If the motor is cranking but not starting you should def. have fuel on your spark plugs. It would be raw fuel with no spark.
Does your fuel pump prime when you turn the power on in the car? Clear the check engine codes and see if the CEL stays on or not with power on only.
Old Sep 24, 2015 | 05:08 PM
tony_2018's Avatar
Fish Twig
Check ground at thermostat housing?
Old Sep 25, 2015 | 01:01 PM
stavri's Avatar
Checked and cleaned grounds also replaced igniter. Still no start. What a waste of $. I checked it prior to changing and was not getting 12 v to one connection. I pulled a plug and checked for spark and got one spark and then no spark at the plug. wtf. Any ideas ?
Also, if I put a test light on the negative terminal of the coil and to the battery and crank the engine-- the light blinks- doesn't that tell me all functions are good up until the spark exits the distributor?
Old Sep 26, 2015 | 03:14 PM
stavri's Avatar
I was thinking - the intake cam controls the distributor timing and the car ran but had misfire codes when I set the cams in the top photo. Then I reset the cams in the bottom photo and the car didn't start and no spark. Should I reset the cams in the top photo or is the bottom photo the way they should be. Thanks for any help.
Old Sep 26, 2015 | 03:18 PM
wunfstgsr's Avatar
Loved
Community Favorite
SMDH!!!!
It should be set like the bottom one dude come on! top pic has timing way off!!!
lower pic has the gears set at TDC BUT did you confirm the crank was at TDC?? prolly why it wouldn't start..
Assembling a engine 101- make sure you know how to set the engines timing belt and set timing..
Old Sep 26, 2015 | 04:09 PM
stavri's Avatar
Yes. The crank was at TDC.
Old Sep 26, 2015 | 04:12 PM
tamboo's Avatar
10 Year Member
word...
http://www.ebay.com/itm/Honda-Integra-B18c1-B18c5-B16A-Cam-Gear-Lock-Timing-Belt-Installation-Tool-/121765284297?fits=Make%3AHonda&hash=item1c59c6c9c9&vxp=mtr
Old Sep 26, 2015 | 06:04 PM
tony_2018's Avatar
Fish Twig
That **** is off....
Old Sep 26, 2015 | 07:06 PM
wunfstgsr's Avatar
Loved
Community Favorite
Double check it may have sliped.
Old Sep 28, 2015 | 09:46 AM
stavri's Avatar
Default Re: Problem solved
After going through the testing of the ICM I wasnt getting 12v to one terminal and determined that I needed to replace the ICM(igniter) . After replacing it the car won't start and would give one spark to the plug and then stop. After thinking about it for a few days and reading the workshop manual for the distributor , which is very good with the flow charts. One thing was to reset the ECM. I disconnected the battery terminals-put a jumper from pos to neg and let sit for a while. I recconected the terminals and the car started right away. It purs like a swiss watch.These cars have very sensitive electronics. Thanks for all for your input and help. When things go wrong your thought process sometimes gets out of whack.
Old Sep 30, 2015 | 11:29 PM
wunfstgsr's Avatar
Loved
Community Favorite
Yea if you dont clear the code the ecu thinks the problem still exsist.
stavri
Sep 21, 2015 06:44 AM
actek988
Jan 14, 2011 05:49 PM
Mik2006
Jul 31, 2009 02:54 PM
jus2sho
Oct 18, 2006 03:44 PM
NeriVTEC
Feb 20, 2006 05:01 PM
