Engine breaking vs neutral and foot brake
Old Sep 21, 2015 | 04:19 PM
93sedansleeper's Avatar
Default Engine breaking vs neutral and foot brake
Ok so I'm fairly new to driving standards and I was wondering what was better - down shifting and rev matching to use the engine to slow down vs just throwing it in neutral and using the foot brake, going down a hill or just a stop light.
Old Sep 21, 2015 | 05:39 PM
holmesnmanny's Avatar
Default Re: Engine breaking vs neutral and foot brake
Brakes are a lot easier to replace than a clutch so ideally you want to use the brakes to slow down however when turning you are going to need to use the clutch anyhow so that's really the only time I use the clutch to slow down because I'm changing gears anyhow.
Old Sep 21, 2015 | 06:42 PM
So when slowing down either on a hill or just coming to a stop at a light you go from 3rd or ,4 th to neutral and just use the foot brake?
Old Sep 25, 2015 | 10:05 AM
BryanM.'s Avatar
Resident Gearhead
When going down a hill I just hit the bakes no need to go into neutral.
When coming to a stop I just hit the brake and stay in the gear I'm in until about 2000 rpm or so then pop it into neutral.
Old Sep 27, 2015 | 02:19 PM
OK thanks
Old Sep 27, 2015 | 03:12 PM
Bently_Coop's Avatar
Steve at Heart
I engine break until it lugs, you can also let off the gas and coast so no to slam on the brakes at the last second.
Old Sep 27, 2015 | 04:54 PM
So how exactly do you do it? Go from like forth then clutch then hit the gas to get the rpms up real quick and down shift then let off the clutch so it doesnt jump back hard
Old Sep 27, 2015 | 04:56 PM
That's what I've been doing and was just seeing if that was better then just braking
Old Sep 29, 2015 | 08:08 PM
Steve at Heart
It is more natural, drop gears and let the engine idle down but not too low. Maybe a 1-2k rpm at most. By the time you go from 5th to 3rd or even second you should be stopped.
Lugging means the engine is struggling to stay on, if you go that far it is to low just enough to let the engine slow you down and aid the brakes at the same time.
crazyhouse2011
Suspension & Brakes
Aug 29, 2014 03:35 PM
Powered by VTEC
13
Mar 12, 2008 12:24 PM
ShinotakuX
Dec 11, 2007 12:28 AM
jxhxb
25
Dec 7, 2007 07:00 AM
gsr camel
Jun 28, 2001 03:08 PM
