1993 honda accord engine mounts
Old Sep 21, 2015 | 11:41 AM
My 93 accord's Avatar
Default 1993 honda accord engine mounts
I was wondering how I would change all my engine mount in my 93 accord lx
Old Sep 21, 2015 | 02:11 PM
Tachi's Avatar
Default Re: 1993 honda accord engine mounts
You unbolt the old ones and bolt the new ones in...
The front torque mount is the easiest to check. Second easiest is the driver's side mount, that one will require a jack and a piece of wood under the oil pan to support the engine's weight. The transmission mount is next assuming you can get the studs out of the bracket the mount rests on. If not then the front and rear mounts have to be undone and the whole passenger side of the powertrain lowered a few inches. The back mount is the hardest to get to as it rquires the intake pipe, and likely the intake manifold to be removed to get it out.
Old Sep 21, 2015 | 03:07 PM
holmesnmanny's Avatar
It's possible to get to the rear by disconnecting the bracket for the heater valve and squeezing it along the rear firewall.
e.p
Feb 24, 2017 07:21 PM
Aseegz
Jul 14, 2013 09:20 AM
LastSamurai
Apr 22, 2011 08:48 AM
Luke G.
Mar 14, 2010 11:53 AM
webhunter
Jan 7, 2006 03:42 PM
