ATI Super Damper Removal? How to remove crank bolt?
Old Sep 15, 2015 | 12:43 PM
deckster333's Avatar
Default ATI Super Damper Removal? How to remove crank bolt?
Trying to remove the crank bolt off my ATI Super Damper, its extremely tight and won't come off even with an air impact. When I had the Honda crank pulley I had the special tool to hold the damper in place and get a large breaker bar on it.
Anyone ever have to remove the ATI Damper? How did you hold it in place?
I called ATI and they have no such wrench/tool, which I think is completely ridiculous.
Old Sep 15, 2015 | 02:48 PM
doood's Avatar
been there done that
Default Re: ATI Super Damper Removal? How to remove crank bolt?
Breaker bar and a really long pipe
Old Sep 15, 2015 | 03:01 PM
Right but what I am asking is how do I hold the ATi damper in place and keep it from spinning.
Forgot mention I have already tried the breaker bar in gear and it did not work.
Old Sep 15, 2015 | 05:27 PM
v4lu3s's Avatar
RTFM
your impact gun is too weak. need one with more torque.
Old Sep 16, 2015 | 04:19 AM
That's a thought, maybe it is time to upgrade my air impact. I have an old Snap-On but I don't know its max output. Have people had success with stronger air impacts?
Old Sep 16, 2015 | 07:13 AM
snobordboy's Avatar
Moderator
<p>I use Ingersol-Rand, as do most of the auto and heavy-duty techs that I know.</p>
Old Sep 17, 2015 | 07:44 AM
v4lu3s's Avatar
RTFM
When i was in a shop we had various brands that did 250lb/ft in reverse. But the shop owned a 3/4" drive that did 600 for tough bolts
Old Sep 18, 2015 | 03:34 PM
Bought an AIRCAT 1150 1/2" Air Impact took the bolt off first try, no problem.
Old Sep 18, 2015 | 03:58 PM
v4lu3s's Avatar
RTFM
that is a beast of an impact gun. beats the **** out of my ingersoll i have, used at the shop and now run at home...
Old Sep 21, 2015 | 06:52 AM
spAdam's Avatar
Loved
Community Favorite
Use anti-seize compound on that bolt when you put it back together and never have the problem again.
Old May 12, 2018 | 05:38 AM
loudes13's Avatar
I know this is an old post, but will the crank tool work with the ATI pulley? My timing is off and I don’t want to damage the valves if they aren’t damaged already.
Before buying a bigger impact, how can I lock down th crank?
jodyboy
13
Jul 1, 2012 11:52 AM
hamilton9339
Aug 18, 2011 10:51 PM
vrrodri
Aug 27, 2006 11:24 AM
xxmastermindxx
Aug 22, 2006 09:22 PM
MCP486
Apr 1, 2003 09:48 AM
