Y5/Y8 hybrid; what's the right fuel pressure?
Old Sep 14, 2015 | 10:39 PM
Gator417's Avatar
Default Y5/Y8 hybrid; what's the right fuel pressure?
I have a few symptoms of low fuel pressure (poor idle & low rpm driveability). I just checked it at the rail & its got between 32 & 34 psi while running, regardless of rpm. It will spike for a split second when goosing the throttle, but is very consistently 32-34 psi. No pressure past the FPR though. I've looked all over this forum and looked at other online sources but haven't found a solid figure yet. I just regapped my plugs, dialed in my tps and set the ignition timing today to take those out of the equation. The plugs were at about .065 - .070, the TPS was off a bit & so was the timing. Also recently installed a freshly cleaned Z6 throttle body with a clean and tight FITV. All of that made a big difference, but then it got worse. Planning on cleaning the IACV tomorrow as well. My setup is Y5 longblock, Y8 intake and exhaust manifolds, Y8 injectors, Z6 throttle body and P28 ECU. Until yesterday it ran really well except just off idle - 1500 or so rpm. Started throwing codes 1 & 43, for bad O2 sensor reading and fuel system issue. Those codes are gone now, but the problem persists. I'm stumped at this point if it isn't the fuel pressure. As always, I sincerely appreciate all of your input.
Gator
Last edited by Gator417; Sep 14, 2015 at 10:46 PM. Reason: edited for content and to fit your screen
Old Sep 15, 2015 | 04:09 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Y5/Y8 hybrid; what's the right fuel pressure?
Old Sep 15, 2015 | 06:17 PM
Gator417's Avatar
Thank you. I guess my 32-34 with the vacuum line attached is spot on. I rechecked my timing today and it was 20° or so retarded. I fixed that and its way better now.
Gator
montanacivic
12
Oct 31, 2015 02:13 AM
TurboGoKart
Sep 30, 2009 02:53 PM
schpiel
11
Oct 23, 2006 12:03 PM
zeekekciv
Aug 10, 2006 04:01 AM
EGbeater
Nov 21, 2003 07:12 AM
