Question about crank position sensor
Hi guys, I just received a code 4 from my 95 civic ex CEL, which is crank position sensor.
I did some research about crank position sensor, the internet said it is local at inside of the distributor.
I am wondering in order to fix the issue, do I have to replace the whole distributor? Or is there any other way to fix that issue?
Thanks
Thanks
Don't randomly replace parts.
Reset the ECU to see if code 4 returns. If so, Ohm test the CKP sensor as well as its two wires.
Google search for a downloadable Helms service manual for your car.
hondasport2000
Aug 14, 2009 01:18 PM
milruner
Dec 14, 2003 06:48 PM
