need help on removing engine
Old Sep 13, 2015 | 01:35 PM
Jjeessee's Avatar
Default need help on removing engine
I have b16 head on a b18 bottom, I have the head off the engine .
Looking if someone can give me a step by step on how to remove the bottom of my engine I don't have a cherry picker so I'm taking my head off (already done) then I want to remove the bottom to make it easier to remove I've looked around at threads but couldn't find one on removing engine , thank you in advance for the help!
Old Sep 13, 2015 | 02:59 PM
2kdrift's Avatar
Default Re: need help on removing engine
This is the same method I use. I cant beleive you cant get info on it as there is plenty you just need to search....
Remove Cv axles/Transmission
Remove any Wiring connected to the block
put a jack under the block and remove mounts
what I do from that point is jack the car way up and remove the block from under the car
Old Sep 13, 2015 | 04:06 PM
Jjeessee's Avatar
I tried finding info I searhed quite a bit found nothing , I still need info on how to remove block an axels, thanks for the respond but I still need detailed info on how to ,would be aorreciated if you could help out thanks!
Old Sep 14, 2015 | 09:24 AM
F22Master's Avatar
So, you figured out how to take the head off, but you cant get the axles out??
Old Sep 14, 2015 | 11:55 AM
spAdam's Avatar
Loved
Community Favorite
This is by far the easiest and most correct way to pull an engine from these cars. Taking an engine out/in from the top is just plain old ***-backwards.
Pull the axles and all mounts except for the driver's side and trans side. Get yourself some 2x4 and build a cradle around the oil pan while the engine/car is still up in the air.
Lower the whole thing down onto an $8 furniture dolly from harbor freight, unbolt the two remaining mounts, and jack the car up high enough to roll the engine out from under it. Installation reverse of removal.
spooty
Sep 9, 2008 03:32 PM
Mugensports187
Nov 9, 2007 06:35 PM
kyosuke714
Dec 12, 2005 05:29 AM
EFin' Kyle
Jul 5, 2004 11:12 AM
metal-x
Oct 22, 2002 10:48 AM
