D16 Dies when given gas only in gear
Old Sep 11, 2015 | 10:02 PM
ChristianEJ6's Avatar
Default D16 Dies when given gas only in gear
I've been working on my civic for two years and it is running and what not. It will start and idle fine, I can give it gas in park and neutral all I want just fine. When I put it in gear it'll do what it should and start moving forward but if I give it gas it will die on me! I don't think it's a fuel problem because I can rev the crap out of it in park. Could it be a part of the ignition? Any sensors? Anything! Please help! Thank you
D16Y7, SOHC non vtec
Old Sep 11, 2015 | 10:41 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: D16 Dies when given gas only in gear
<p>Is the CEL on? &nbsp;Does it work? &nbsp;What ECU are you using? &nbsp;What transmission are you using? &nbsp;Check your mechanical and ignition timing.</p>
Old Sep 12, 2015 | 08:15 AM
CEL is on but I can't take it anywhere to scan it. Does what work? The stock automatic transmission for the D16Y7 and the stock ECU for it, not sure what they are. But I know mechanical timing is set right and timing belt is good. Can I set the ignition timing myself without the timing light tool?
Old Sep 12, 2015 | 08:24 AM
boozer's Avatar
Your ignition timing is usually controlled by the ECU. But if you feel your "starting point" is off, you can simply adjust it by breaking loose the three bolts that hold the distributor to the head and turning CW or CCW. Advance, retard. I would start with pulling that CEL code.
Old Sep 12, 2015 | 09:20 AM
NotARaCist's Avatar
<p>You don't need to take it anywhere.</p><p>https://honda-tech.com/honda-civic-d...lists-1901557/</p>
Old Sep 12, 2015 | 10:56 AM
I might know someone who has a CEL scanner. But I just found out it does hesitate in park also just not as bad as in drive
Old Sep 12, 2015 | 11:33 AM
tony_2018's Avatar
Fish Twig
When was the last time you did a tune up.
Old Sep 12, 2015 | 11:40 AM
Spark plugs are new, distributor cap is fine, air filter is new but aftermarket. That's it really that's new. Fuel pump is new also.
Old Sep 12, 2015 | 11:42 AM
tony_2018's Avatar
Fish Twig
How long ago? Why were the wires not replaced? When was the last time you tested the igniter and coil?
Old Sep 12, 2015 | 11:54 AM
Everything was about a year ago but it's been sitting in the garage for two years. Me and my dad got it as a project car. I will get wires, ignition coil, etc.. when I get paid. But all four wires are working so ignition is good right? Except for ignition timing maybe?
Old Sep 12, 2015 | 12:18 PM
tony_2018's Avatar
Fish Twig
visually working........but did you check them? DIAGNOSTICS. Check the faq section on how to perform them.
Old Sep 12, 2015 | 12:40 PM
While the car was running, took one at a time out. I will just buy new ones when I can to be sure though
Old Sep 12, 2015 | 03:47 PM
tony_2018's Avatar
Fish Twig
Oh....I believe you just made it worst. Thats not a good way to test.
Old Sep 12, 2015 | 05:01 PM
NotARaCist's Avatar
<p>If you're going to ignore the questions posed to you, what makes you think we can help you? &nbsp;We aren't psychics. &nbsp;If you don't do the tests we ask you to do, we can't help you.</p>
Old Sep 12, 2015 | 08:15 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
CEL light on, provided the link on how to pull CEL codes via service connector and blink codes, yet still no knowledge of what CEL code is stored/active.
I suspect the CEL code will likely provide a pretty solid insight before parts get trashed by random testing.
Old Sep 12, 2015 | 10:35 PM
I didn't test the wires today, that was a few months ago. sorry I didn't get to messing with the car today. I will get the CEL code tomorrow sometime and let you guys know. I was at work until 11:30 tonight, sorry
Old Sep 13, 2015 | 10:52 AM
I reset the ecu and drove it down the street, it died a few times but no engine codes were thrown. Could it be carbon buildup in the manifold/throttle body? or could it simply be that the fuel tank is really low?
Old Sep 13, 2015 | 10:57 AM
Also plan on buying all the tune up parts when I get paid. What's everyone's opinion on seafoam? I did it on my Acura along with a tune up and it runs a ton better now, it had a really bad carbon problem. Also going to go to my grandpa's house to grab and ignition timing light when I get the chance and make sure ignition timing is good
Old Sep 13, 2015 | 11:02 AM
JDM-sol 89's Avatar
OP, you stated previously that you and your father got this as a project car. What parts have you guys replaced, cleaned, tore apart, etc. Also, what condition was the car when you two got it? Was it running?
Old Sep 13, 2015 | 11:39 AM
The car wouldn't start when we got it, when it would it wouldn't stay idling. We are using a block with lower miles and the same head and intake. Really the only things that are new are spark plugs, fuel pump, radiator, radiator hoses, intake manifold gasket, head gasket is new. I will be putting gas in it, getting new distributor cap and rotor, and wires when I get paid. Anything else I should get? There might be a couple new things that I can't remember at the moment.
Srt.ej1
Oct 22, 2015 10:23 PM
jdm36
27
May 3, 2011 11:31 AM
tmdctfan
Mar 9, 2011 04:42 PM
deemy72
Apr 20, 2009 06:50 PM
JBk24crx
Jan 22, 2004 12:50 PM
