WTB Screws for rotor
go to the dealer to pick some up, but as others have said, you don't really need these screws. when you mount your wheels, the lugs will keep the rotor from moving. sounds like you have some other problem with your squeaking brakes.
good luck
good luck
Someone please help me out here!
you dont need them
all they do is hold the rotor so it dosent move while you install your wheels.
after the wheels are installed the lugs hold it on.
i dont use them
90% of the road racing forum dosent use them
all they do is rust to your rotor and make it HARDER to take off.
they are pointless.
the breaks arent squeaking. It sqeeks while I drive. When I apply the breaks the squeak goes away. I know its gotta be the rotor and the screws because it wasnt doing that before. They stupid shop i went to, to get my coilovers installed forgot to put them on.
its 1 of 2 things
1) they didnt grease the back of the pads and the shim
2) you have cheap crappy brake pads. or a racing pad (like axxis ultimate, hawk HP+ etc)
ALSO new pads may squeak for a little bit because if you didnt have your rotor turned they need to match the surface of the rotor.
[Modified by KAMiN, 6:24 PM 11/5/2002]
amej8
24
Apr 27, 2007 05:15 PM
ImportechPerformance
38
May 8, 2003 07:38 AM
