primary o2 sensor help
Old Sep 10, 2015 | 02:23 PM
Shay Cothran's Avatar
Default primary o2 sensor help
I have a 96 civic ex and I'm having trouble with finding my primary o2 sensor. I have dcs Header and and an aftermarket exhaust (not sure what kind because it was on the car when I bought it). I also can't find the connector plug for the o2 sensor. I was told it is on the exhaust manifold but there is no connector plug there. My friends 99 ex has both under the car. One before the cat and one after. I have one before my cat but nothing after. By what I heard the one directly under the shifter is the secondary o2. That is the only one I can see. Is there something I'm missing or don't know?
Old Sep 10, 2015 | 02:27 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: primary o2 sensor help
Nope, that's the connector you're looking for.
If you're only running one, and there's no check engine light, your car is more than likely OBD1 now.
Old Sep 10, 2015 | 02:45 PM
So that's the primary and I don't have a secondary? The bulb has been removed from cel and oil pressure. I'm getting the bulbs today. I'm sure my cel will be on when I put the bulb in. Autozone said I have codes for primary and secondary o2 sensor. I plan on replacing the one under the shifter. Just don't want that one to go bad after replacing due to the other one not working
Old Sep 10, 2015 | 04:40 PM
If I can't find the other o2 sensor can I get a odb2 yo odb1 jumper harness and get a different ecu then tune it to not worry about the other o2 sensor?
Old Sep 10, 2015 | 07:37 PM
Former User's Avatar
Important details are missing in the first post. Is the car stock except the header and exhaust? D16Y8 engine? What ECU?
Old Sep 11, 2015 | 02:32 AM
Everything is stock but what I listed and cai. D16y8 with p2p.
Old Sep 11, 2015 | 02:47 AM
HondaPartsHero's Avatar
Technical Hero
The 96-98 EX has the primary at the front of the manifold like so
https://honda-tech.com/honda-civic-d...d16y8-2945177/
Old Sep 11, 2015 | 03:14 AM
[QUOTE=HondaPartsHero;50526245]The 96-98 EX has the primary at the front of the manifold like so
I already stated I have a header instead of exhaust manifold. Also I can't even find the connector wire for the o2 sensor to plug into.
Old Sep 11, 2015 | 04:50 AM
You're seeing two O2 sensors, so you're not missing anything.
Old Sep 11, 2015 | 07:51 AM
But I am not seeing two. All I see is the one under the shifter. That one is the location for the secondary o2 sensor right? If so then I don't have a primary o2 sensor or can't find the sensor nor the plug from the wiring harness
Old Sep 11, 2015 | 05:23 PM
Technical Hero
What color are the wires on that sensor?
Old Sep 12, 2015 | 07:15 AM
The wires coming out the sensor are two black and one green.
Old Sep 12, 2015 | 07:18 AM
I've been trying to upload pics but when I do, it disappears after my pic uploads 100% so I can't insert the pic.
Old Sep 12, 2015 | 07:30 AM
That is the only o2 sensor I see.
Old Sep 12, 2015 | 07:36 AM
The O2 sensor has 4 wires. When you describe wire colors, first state the main color followed by the stripe color, for example Blk/Wht. For one color wires, just the main color, for example Blk/Wht. Better yet, post pictures of the connectors and the attached wires.
Old Sep 12, 2015 | 07:40 AM
Ok. I will send better pics of the sensor and connector when I get my car unpacked. I'm also in the process of moving.
Old Sep 13, 2015 | 02:40 PM
ok. I got some time to look at it better and take pics. There is one black with white stripe, one black, one green, and one white. there is no connector. Just wired together. black to black, green, to green, white to whit, and black with white stripe to black with white strip.
Old Sep 13, 2015 | 03:19 PM
ok. I got some time to look at it better and take pics. There is one black with white stripe, one black, one green, and one white. there is no connector. Just wired together. black to black, green, to green, white to white, and black with white stripe to black with white strip.
Old Sep 15, 2015 | 01:49 PM
As you can see I posted pics as your requested. Do you think you can give me some feedback. Also I believe I have found a spot for my primary o2 sensor to go on my header. Looks like there is a plug in there. Can you confirm that plug is where the primary o2 sensor goes? Bad pic but the plug is in the top left corner. Thanks
Old Sep 15, 2015 | 01:52 PM
Also if that is for the primary O2 sensor do you think I should put it in and wire the o2 sensor straight to the ecu myself?
Old Sep 15, 2015 | 02:17 PM
2LEM1's Avatar
I like to party
Community Builder
your best bet is a jumper harness and a P28.
Old Sep 15, 2015 | 02:30 PM
I was already looking into that but wouldn't I still fail inspection?
Old Sep 16, 2015 | 08:20 AM
09chaplak's Avatar
Loves Tossing Salad
You'll still fail with that test pipe in there sooooooo
Old Sep 16, 2015 | 08:46 AM
I beg to differ. There is a lot of people in Houston that have passed inspection with test pipes soooooooo.
Old Sep 16, 2015 | 09:07 AM
09chaplak's Avatar
Loves Tossing Salad
I beg to differ. There are a lot of people in Houston that have passed inspection with test pipes soooooooo.
FTFY bruh.
Good luck!
stereo
Dec 2, 2008 07:26 PM
'96typeR
15
May 17, 2008 11:13 AM
'96typeR
May 12, 2008 12:16 PM
Hybridize
Oct 17, 2003 01:56 PM
DestinLnGa
Sep 23, 2002 08:47 AM
