Skunk2 Alpha 70mm throttle body TPS issue
Old Sep 10, 2015 | 10:53 AM
PR8urVtec's Avatar
Default Skunk2 Alpha 70mm throttle body TPS issue
I bought a skunk2 Throttle body. The Alpha 70mm and I'm having problems with the TPS. It's incredibly hard to turn the TPS sensor to make adjustments. Even with no screws in place. It's almost like the TPS doesn't fit in the skunk2 part. Works fine on the OEM unit. Just trying to calibrate the damn thing. Has anyone ran into this problem? Is there something else I need to adjust to make it work??? Please spare me the junk2 comments. I need useful information. I have a JG edlebrock manifold so I need larger than stock TB.
Old Sep 10, 2015 | 01:39 PM
bspeed's Avatar
Default Re: Skunk2 Alpha 70mm throttle body TPS issue
I have an alpha and it installed no issue. Didn't have to adjust a thing. I had a bin of old TPS sensors and had to try a few because I never labeled them, once I had the right one it was perfect. I think it came off a GSR. Try to email S2 customer service if nothing else works.
Old Sep 10, 2015 | 05:45 PM
PR8urVtec's Avatar
That's a good idea. I should have done that haha. I'll give them a holler and report back when after I hear what they say. Just wanted to see if anyone has heard or encountered the problem. It just fits really snug and then I have to hit the TPS sensor with something in order for it to turn any. My OEM TB was loose enough that if I loosen the screws i could turn it with ease to get the correct angle. Just weird.
slowEGles
Apr 6, 2014 03:39 PM
Dead CIVIC
11
Aug 16, 2009 10:44 PM
TuningBrasil
Jun 5, 2008 06:06 PM
b16nonoy
Mar 12, 2007 09:21 AM
bootlegtrader
Oct 19, 2005 08:15 AM
