87 Si highbeams don't work...
Old Nov 5, 2002 | 12:51 PM
B_CRUZ!'s Avatar
Default 87 Si highbeams don't work...
I know the bulbs aren't the problem and the fuses are all good. Where is the relay for it?
TIA
Old Nov 6, 2002 | 08:18 AM
EF_LSVtec's Avatar
Default Re: 87 Si highbeams don't work... (B_Cruz)
If relay's bad, it wouldnt work at all. Check the switch.
Old Nov 6, 2002 | 08:43 AM
B_CRUZ!'s Avatar
Default Re: 87 Si highbeams don't work... (EF_LSVtec)
so your saying that the low beam and high beam shared the same relay?
the high beams don't work at all. when i flick them on, the headlights turn off but no high beam and the blue light in the cluster doesn't work either
Old Nov 6, 2002 | 11:44 AM
PnX-R's Avatar
What I'd do is check for power at the Load.. Go to the High Beam socket and check to see if you've got power coming to it. If not, I'd check the switch..
Old Nov 6, 2002 | 11:46 AM
B_CRUZ!'s Avatar
Default Re: 87 Si highbeams don't work... (PnX-R)
cool thanks
EdK
Honda Civic (2001 - 2005)
Jul 9, 2013 01:01 PM
jonesEK
Feb 10, 2010 01:46 PM
wardseg6
Dec 27, 2007 05:52 PM
em2_blk_01
Sep 28, 2006 12:33 PM
yeegsr
15
May 1, 2005 07:39 PM
