High beams wont work!
I think this happened all of the sudden I tried to switch on the high beams and noticed that both of my lights just turn off when i switch them on. I tried replacing the bulbs replaced and checked all of the fuses and nada! anyone know what could be wrong thanks a lot for ur help
all of the other lights work fine except a foglight which is blown. but i think thats irrelevant.
Re: High beams wont work!
Go to your local junk yard and get a new switch..I think that is what is wrong.. Happened to my buddy and he had the same problem and we swapd in new switch posts and WALA...So i would try that its a cheap fix, and some what easy to start with!!
Good luck
Good luck
PHANTOM MENACE
Did they both go out at the same time? If so, my first guess would be the switch also. Do you have a multimeter? If so, do you know how to use one? If yes, check to see if the bulbs are getting voltage. If they're not check to see if the fuses are getting voltage.
GSR936
12-07-2008 01:53 AM
EM1Guru
11
10-24-2003 06:57 AM
