Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
ABS code 25???
Old Sep 8, 2015 | 07:43 PM
flyinghigh14's Avatar
Default ABS code 25???
VSA Light On- Honda Accord Coupe 2009
Hello! My 2009 Honda Accord Coupe LX-S, has been having an issue the past 5 months in which the VSA light and the exclamation point come on almost every time I drive the car. Funny thing is I notice nothing different with the car with the light on or off.
I observed the VSA light and exclamation point come on while I'm at a full stop for an extended period of time like at a stop light. Once those two lights pop up, the VSA Off button no longer works. Once, I restart my car's engine, the light goes awat but then comes back when I'm stopped.
I researched a lot about this topic and I've already changed out the brakelight switch, checked brake fluid level, checked brake pad thickness, checked fuses, wheel sensors, ect. I jumped pins 4 and 9 on the OBD connector and I get the flashes for code 25. I cleared the code and the code reappears after a short drive. I tried the VSA sensor neutral position memorization procedure with no luck- have not been able to successfully complete it for some reason.
I was wondering if anyone can tell me what is code 25? I looked online and some people stated it is the Yaw Rate sensor. If anyone has any insight please let me know! Thanks.
v6veggie
Aug 16, 2014 02:35 AM
mousiex113
Jun 29, 2006 06:00 PM
anonchild
Feb 20, 2006 05:13 AM
dynamo
Nov 1, 2004 08:50 PM
Typiko512
May 20, 2003 10:27 AM
