Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
05 V6 Accord blinking "D" light
Old 08-12-2014, 12:23 AM
v6veggie's Avatar
Default 05 V6 Accord blinking "D" light
Started driving my car and all of a sudden the D light started blinking, pulled over and put the car on park, light kept on blinking, turned off the engine, turned on again and the blinking stopped, mechanic said it's the abs unit, will cost me around $1600.00?! please help!!
Old 08-12-2014, 03:43 AM
shotout@ccord's Avatar
Default Re: 05 V6 Accord blinking "D" light
Mechanic? Was it a Honda dealership? Or was it a guy with a really high end computer scanner?
if you slam on the brakes do the wheels lock up?
Old 08-12-2014, 03:57 AM
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
usually a blinking D light indicates a transmission issue, make sure this guy isnt just trying to rip you off on parts
Old 08-12-2014, 04:03 AM
most scanners wont read the transmission codes right, try going to the dealer to get the code read or a good transmission shop, which will have the right scanner to read those codes, there's a good chance it's just the third or fourth gear pressure switch, if the fluid looks ok, and it's driving ok, those pressure switches have a tendency to fail
Old 08-12-2014, 05:09 AM
Global Moderator
tech8's Avatar
Generally, OBD-II readers/scanners can easily read transmission trouble codes, as they are powertrain related ("PXXX"). So, there is no need to go to a transmission shop just to get the code read.
In contrast, not all code reader/scanner are capable of reading Honda ABS/SRS code(s).
OP should get the car scanned with a OBD-II scanner capable of reading Honda ABS/SRS codes and post the code.
Old 08-12-2014, 05:12 AM
I agree, everything I've found says the scanners can only read engine codes, hoping it's something as simple as a pressure switch
Old 08-12-2014, 05:33 AM
ronaldmcdonald9's Avatar
a good enough scanner will read a trans code, abs i dunno never tried
Old 08-12-2014, 01:10 PM
BLKFLSH's Avatar
If it were a problem with the ABS, the ABS light would be on. Sounds like this mechanic is confused.
Old 08-15-2014, 09:45 PM
Fish Twig
tony_2018's Avatar
Certain scanners can read all codes, you just need to identify the scanner that can read what you want it to read. The prices vary on them as well so keep that in mind.
Old 08-16-2014, 02:35 AM
Fish Twig
tony_2018's Avatar
I see you made a world record, 3 bans in 1 yr.
flyinghigh14
09-08-2015 07:43 PM
awb594
07-02-2012 10:08 AM
Yonas Yonni
Transmission & Drivetrain
05-07-2012 01:45 PM
coolie2609
01-16-2012 09:38 AM
fijo
10-30-2006 07:53 PM
Quick Reply: 05 V6 Accord blinking "D" light
