'95 Civic auto trans /d15z1 with p06-1 ecu. And it runs
Old Sep 5, 2015 | 05:47 PM
Darrell Woods's Avatar
Default '95 Civic auto trans /d15z1 with p06-1 ecu. And it runs
I bought a p28-A52 ECU from ebay . Hooked it up.
Car will Not start up as it Does Not activate the Fuel Pump. HELP.
I bought this ecu To activate the VTEC.
Any any All help is Seriously appreciated..
Old Sep 5, 2015 | 09:12 PM
Former User's Avatar
Default Re: '95 Civic auto trans /d15z1 with p06-1 ecu. And it runs
CEL remains on steady?
Any spark at the plugs?
A D15Z1 engine uses a P07 ECU.
Also test the main relay.
Check fuses 31 and 24.
Old Sep 5, 2015 | 09:33 PM
slogfilet's Avatar
But is there a P07 auto ECU?
Is this a stock US D15Z1, or the JDM/EDM equivalent?
Old Sep 5, 2015 | 11:10 PM
tony_2018's Avatar
Fish Twig
check the engine code, or take a picture. if it is a d15z1 you need a p07
Old Sep 6, 2015 | 01:38 AM
eHMxhACk's Avatar
yippee-ki-yay
Recently at the junkyard I saw a D15Z1 block and head (P07) with a P08 intake and not the standard Z1 exhaust manifold. The trans was covered in oil, but it was an auto. Someone had already taken the ECU so I'm not sure what they were using.
OP, the VTEC (VTEC-E) you're trying to activate is only going to give you one additional intake valve per cylinder above 2500rpm. Non-VTEC is a 12 valve mode, VTEC is a 16 valve mode. At 5500rpm that engine will produce 92hp on a good day new from the factory.
The only person you'll impress with that is a guy riding a donkey.
eH.
Old Sep 6, 2015 | 04:37 AM
HondaPartsHero's Avatar
Technical Hero
There is an auto JDM P07, that's your only hope
Old Sep 6, 2015 | 06:25 AM
tony_2018's Avatar
Fish Twig
Very rare though, I think I found one on ebay in the uk one time, decided not to go with that.
Old Sep 6, 2015 | 10:17 AM
My civic Runs with the p06 ecu. But with not rev past 4000 rpm. So I bought p28 -a52 ecu but Mil light never goes off and the fuel pump never engages. I put the p06 ecu Back on the car. It starts up and runs Ok.
siblues
Engine Management and Tuning
Nov 8, 2023 10:43 AM
akouznet
May 24, 2009 06:50 PM
nihkon
May 18, 2002 01:51 AM
Zeus Zore
Apr 1, 2002 03:06 PM
H22ACiViC
Feb 13, 2002 07:05 PM
