01 gsr starter probz
Old Aug 29, 2015 | 10:01 PM
nicknack25's Avatar
Default 01 gsr starter probz
So i've rebuilt my starter contact points with a set like this:
Amazon.com: Starter Rebuild / Repair Kit For Later Model Denso 1.4kw Gear Reduction Starters (w/ Plunger & Contacts): Automotive Amazon.com: Starter Rebuild / Repair Kit For Later Model Denso 1.4kw Gear Reduction Starters (w/ Plunger & Contacts): Automotive
I got the points and the plunger, but it only worked for a couple of weeks until my starter started clicking again. Took out my starter and the points had some corrosion on em already so i just cleaned em up and slapped it back in. Worked for a couple weeks again and now it's clicking again. Sometimes it starts up right away though, its doesn't just click all the time.
I've read the comments on this thread: Rebuild your starter for less than $20 - Team Integra Forums - Team Integra
and 96acuraintegra said:
"the gears can be, and most of the time are, worn down. The armature could be corroding and could need a sanding like on a lathe. The brushes may be worn, which is almost always the problem, and the fields may have a tear in them. There's so much to it, but yes, changing out the contacts is one source of problems for a bad starter."
Now does anyone know how to actually know how to inspect/replace the armature/brushes? Or should i just get a new starter?
Old Aug 31, 2015 | 02:17 PM
tamboo's Avatar
10 Year Member
Default Re: 01 gsr starter probz
Starter Motor Repair
Old Sep 3, 2015 | 12:16 AM
nicknack25's Avatar
Originally Posted by tamboo
Dude that's awesome! Thanks Bro. It seems like a lot work though..
Myb20integra
Sep 15, 2014 02:14 PM
Dreamw3rkz
Oct 2, 2008 03:39 PM
WhiteLightening
Jun 6, 2004 04:17 PM
AmplifiedGSR
Feb 4, 2004 03:08 PM
