96 Civic Accessory Power Relay
Old Aug 29, 2015 | 03:01 PM
jwnuttall's Avatar
Default 96 Civic Accessory Power Relay
I have a 96 Civic, 2 door, for which the radio works intermittently. From what I have read it looks like the problem is probably the accessory power relay. However, I don't know where that is located. Does anyone know where it is or have a diagram that I can look at of the location? Thanks.
Old Aug 29, 2015 | 04:16 PM
Former User's Avatar
Default Re: 96 Civic Accessory Power Relay
There's no accessory power relay.
Old Aug 29, 2015 | 04:20 PM
jwnuttall's Avatar
Ok. Is there something else that would cause that problem? Another relay or fuse or something?
Old Aug 29, 2015 | 04:23 PM
Start here:
Loose fuse (2 for radio), or loose wire or connector at rear of radio.
chrysler kid's Avatar
You'll need to be more specific.
Factory radio?
Is it turning on and off?
Check the wiring harness to the radio
Old Aug 29, 2015 | 04:26 PM
SidPM-EG6's Avatar
i wud rly say thats the earth not well connected to the chassis
Old Aug 29, 2015 | 08:47 PM
jwnuttall's Avatar
It will sometimes turn on with the key switch and sometimes not. If not, sometimes it turns on while I am driving. Other times it will turn off while driving. It can work for a while at a time or just a few seconds. I'll try your suggestions. Thanks.
Old Aug 30, 2015 | 05:42 PM
SidPM-EG6's Avatar
Has the radio actually ever worked fine before?
Old Aug 31, 2015 | 02:27 PM
jwnuttall's Avatar
I just recently purchased the vehicle and it had this problem when I got it. The radio is aftermarket, though, so the problem may have been caused by a bad installation. I will have to wait until this weekend to look into it further, though. I imagine it must be a bad/loose ground, fuse, or wire. I'll let you know what I find.
Tie Ee Fei
10
Jan 11, 2019 09:34 AM
S1LENT94D00R
Sep 7, 2012 09:05 AM
jdreadjdm
Jul 1, 2012 04:35 PM
ser13
Dec 26, 2007 12:58 PM
