Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Power steering pressure switch
Old Aug 27, 2015 | 07:21 AM
malcolm2's Avatar
Default Power steering pressure switch
2004 Odyssey
replacing high pressure line with the switch in it and noticed that the electrical connector to the PS switch was cut in two, right at the switch harness connector. No wire to splice to. Once the line is out, maybe I can see if the connector can be re-wired. Any ideas on fixing this?
What does this switch do anyway?
Suggestions on fixing it.
BTW this is a great video on pulling the line out.
Old Aug 27, 2015 | 10:08 AM
malcolm2's Avatar
Default Re: Power steering pressure switch
Lots of lookers so far, no help yet.... That gave me some time to investigate. The connector is a part that must fail, cause I found it for sale.... $15 to $30 with wire splices. Pull-a-Part here I come.
Also found a YouTube video explaining the operation of the switch. At LOW pressure, driving at 2-3K rpm, the switch is grounded (0 volts) at high pressure it picks up the battery voltage (12 volts). At 12 volts (when turning the steering wheel and idling or not moving) the pump could drag down the engine idle. So the 12 volts tells the CPU to up the RPM so the van won't stall. A bit of over engineering, if you ask me.
My van does not stall, so maybe I am good without it.
Does that sound right?
Old Aug 30, 2015 | 01:40 AM
poorman212's Avatar
The PSP is for just that....it works a bit different than your description but in the end it is an input to the PCM for adjusting the idle speed.
Yes a bone yard trip sounds like it is coming.....I'd also be willing to bet that almost any Honda will have the coorect size connector, so don't get too hung up on finding the same gen Ody.
Old Aug 31, 2015 | 05:08 AM
malcolm2's Avatar
WOW, that had to be the toughest job I have done on a car. Part of the problem may be the AutoZone version of the hose/line. It seems that the curves and bends are not exactly right. Plus the sensor bung does not end up pointed to a clear space.
Unlike the video, I had to thread my replacement line from the driver's side wheel well, I could not get the flared end to reach the connection when I started at the top. Plus I had to take the Sensor off in order to get the line all the way thru. Then re-attach it once I had the line threaded.
But I got it done and I don't currently see any leaks...
So I would recommend a HONDA PS OEM hose/line.
Old Aug 31, 2015 | 02:56 PM
poorman212's Avatar
Glad you got it done......reminds me of doing a PS line on a 3rd gen Accord. Starts at the pump at the front of the drivers/left side, goes from the front of the engine to the pass/right side. Then down by/over the trans, at the rear of the trans/engine is turns back to the drivers side. Finally connects to the rack almost under the drivers feet. One big "C Shape" around and thru the engine bay
Good luck with the PSP connector.
Old Jul 27, 2023 | 04:21 AM
efz's Avatar
efz
Interesting that this is a thing. I was changing the CV boot on my 2014 odyssey yesterday
Cut PS pressure switch Odyssey 2014. no noticeable effects dont know how long
and noticed the same thing. cut wire 1/4 from the connector. Have no clue how long it was like that. Maybe squirrels!
Have not noticed anything driving... It is to increase idle when steering is on full lock, normally in parking situations.
Too much work to fix really but I will look up your parts!
bertsb18hatch
Engine Management and Tuning
Sep 16, 2008 10:28 PM
Threads
11
Jun 28, 2006 04:52 PM
morepoop4u
Mar 14, 2005 04:07 PM
