I Backed into a pole about a month ago.
Old Aug 25, 2015 | 03:24 PM
Zeronamous's Avatar
Icon4 I Backed into a pole about a month ago.
Here are some images of how it looks now:
https://i.imgur.com/66BQ8am.jpg
https://i.imgur.com/qxMenjd.jpg
https://i.imgur.com/V7dMMsS.jpg
Any recommendations on fixing it entirely? I used a deadblow to get everything popped out enough to put another taillight in. I couldn't get the big one out though. I also want to close that gap by the trunk.
Old Aug 28, 2015 | 11:15 PM
Hidenplanvew's Avatar
Default Re: I Backed into a pole about a month ago.
Not trying to be a dick, but the dead blow prob did more harm then good. The Metal will have to be replaced to look right w/o a ton of filler. If you don't care, just hook a come along to it and hope for the best.
Old Oct 12, 2015 | 11:25 PM
GSRCivic98's Avatar
That is a easy fix if you have the tools and a lot of time. Use a dent puller it will weld studs into your damaged area. but before then you will grind down all the paint off the area then get the studs in. Then you will use a stud puller along with a dollie and a shrinking hammer to bang out the metal to it's shape. After all of this you will then need fiberglass resin then sand and then use plastic filler and prime.
tepid1
Paint and Body
10
Mar 15, 2010 07:07 PM
Spoolbeast
Paint and Body
Oct 16, 2009 06:36 AM
ToxicFabrication
Welding / Fabrication
39
Jan 8, 2009 01:57 PM
Integra4lyfe069
Apr 21, 2008 05:13 PM
640K Crew
Jan 28, 2006 08:43 PM
