Are all the d series driveshafts identical?
Old Aug 23, 2015 | 03:18 AM
rusty_eg3's Avatar
Default Are all the d series driveshafts identical?
Hi everybody. I'm new to this site, hope there isn't another thread with this question because if it is, I couldn't find it. My question is: Are all the d series driveshafts identical? I have a 94 Civic eg3 with d13b2 (Europe model). I'm considering replacing the driveshafts and I want to know if I can take them from a d16z6 Del Sol. I already swapped the knuckles with the ones from the Sol i was talking about, keeping the original d13 driveshafts so i know that this isn't a problem, but will they fit on the other side? Thanks!
Old Aug 23, 2015 | 03:49 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Are all the d series driveshafts identical?
I can't speak for the d series in other countries but in the US the 92-00 d series axles are interchangeable. The only difference would be if your car had ABS it would have a tone ring on it and would need to be swapped over if the donor axle didn't have it.
Old Aug 23, 2015 | 03:59 AM
rusty_eg3's Avatar
My car and the donor both lack the ABS system. I guess there's no difference between USDM and EDM models mechanically speaking, just that the d13b2 1.3 16v 75HP PGM-Carb engine which I have was sold only in Europe and maybe Japan (not sure though).
Old Aug 23, 2015 | 06:35 AM
ek9_beast's Avatar
All dseries from 92-00 call for the same axles. Even whether it's automatic trans or stick is irrelevant. Only difference would be the abs ring
Old Aug 23, 2015 | 08:49 AM
rusty_eg3's Avatar
Thank you both for your answers. I just needed to confirm the rumor that I heard before disassembling half the car...
Old Aug 25, 2015 | 08:07 PM
mattliston's Avatar
What kind of mis-information is this?
no, EG and EK axles are not the same.
Yes they "fit".
OP, del sol fits into EG *chassis* style, so yes, you have axles to swap. do work!.
Others puking incorrect information. Do a google search yourselves.
EG and EK have different compressed and non-compressed axle lengths.
There is a reason EG and EK do NOT share subframes even.
Old Aug 25, 2015 | 10:29 PM
ek9_beast's Avatar
I just went to tech parts express last week. I bought axles for my 99 manual trans d16. My coworker bought axles for his 94 automatic transmission d16z6. Same exact axles. Same part numbers so where's the misinformation?
92-00 d16 share axles
Left 773-708
Right 500-505
88-91 d series have different length axles than 92-00
Old Aug 26, 2015 | 02:31 AM
Technical Hero
I've used them interchangeably for years with no issues. I don't need to google search experience.
Old Aug 26, 2015 | 02:37 AM
ek9_beast's Avatar
That makes two who do it/ have done in regularly.
Old Aug 26, 2015 | 04:27 AM
mattliston's Avatar
honda oem part number
found MY misinformation
OBD0 versus OBD1/2
between OBD1 and 2 only a few millimeters driverside, but passenger side has a bigger difference between eg and ek
Old Aug 26, 2015 | 05:48 AM
ek9_beast's Avatar
Bottom line is 92-00 d series are interchangeable auto or manual. The 88-91 will not work for 92-00
Old Aug 27, 2015 | 01:02 PM
hondur's Avatar
Dur Da Dur
5 Year Member
the axles have different # of teeth right?
Old Aug 27, 2015 | 02:00 PM
ek9_beast's Avatar
left axle is longer, right is shorter than 92-00
88 axles 21 spline
89-91 axles 20 spline
Old Oct 4, 2021 | 04:19 PM
Wizard_Harry's Avatar
Hi, I’m doing a manual swap on my 98 JDM ZC ABS auto Integra (that a mouthful). Have found a D series gearbox for it but am having trouble finding axles. Some people have said I need manual D series axles specifically for an Integra and others said I can use the auto ones and just bolt an intermediate shaft on.
Hoping you could clear this up for me?
Old Oct 6, 2021 | 07:42 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
PM the user, this thread is from 6 years ago and the user may or may not be active on the site anymore.
bcperformance
Nov 19, 2013 12:15 AM
hondatech8798
Oct 16, 2012 01:31 PM
Paseo564
Honda Civic (2001 - 2005)
Jun 22, 2008 08:40 AM
turbohenry
Mar 29, 2008 05:18 PM
murray195
Dec 12, 2007 08:52 AM
