Obd2a or Obd2b?
Old Aug 19, 2015 | 11:58 AM
Torleif's Avatar
Default Obd2a or Obd2b?
Hi!
I have a 96 civic ej9 with a b16b swap and a ek9 ecu. Both the engine and the ecu are obd2b, but the stock chassis harness is obd2a.
My question is, will the stock obd2a harness communicate with a obd2b engine harness? Or do i have to use a obd2a engine harness and a obd2a to obd2b jumper for the ecu?
Have been searching for an answer to this but with no luck. But maybe someone here knows?
Old Aug 19, 2015 | 02:50 PM
DumpdEJ6's Avatar
I like the tuna here
Default Re: Obd2a or Obd2b?
i believe you will have to use a jumper, if I'm not mistaken there is a whole plug on OBD2A that isn't used on OBD2B.
Old Aug 19, 2015 | 03:58 PM
tony_2018's Avatar
Fish Twig
Originally Posted by Torleif
Hi!
What obd2a harness are we talking about, specifically what I put in bold
Old Aug 19, 2015 | 06:47 PM
Moi Moi's Avatar
I been loking for a obd2b pct ecu... i have what you need pct obd2a... if you want to trade send me a pm... and yes you need a obd2a engine harnes
Old Aug 19, 2015 | 06:48 PM
Moi Moi's Avatar
You can buy a obd2a ex harness... and plug and play.. with a obd2a ecu
Old Aug 19, 2015 | 11:11 PM
Torleif's Avatar
The harness that is under the dash that goes to the speedo etc..
Old Aug 19, 2015 | 11:34 PM
Torleif's Avatar
That would be a great deal, but i live in Norway so a little difficult to do.
Old Aug 19, 2015 | 11:41 PM
98EGY8's Avatar
10 Year Member
^this or get obd2a ecu instead of jumper, which ever is cheaper. and as Moi Moi mentioned, youll want a 96-98 mt ex harness
Old Aug 20, 2015 | 12:32 AM
Torleif's Avatar
I have read that you can use a auto harness, just don't use the auto plugs. Is that possible? They are much cheaper than mt harness.
Old Aug 20, 2015 | 02:15 AM
HondaPartsHero's Avatar
Technical Hero
I don't believe he's in the US if he has an EJ9. You'll need then engine harness for whatever engine in your country uses a B series VTEC that is OBD2A. I don't believe anyone makes a jumper harness for your ECU as it only uses 2 plugs instead of the usual 3.
Old Aug 20, 2015 | 05:29 AM
tony_2018's Avatar
Fish Twig
Would be nice if they state that fact.
jaelynrei
13
Sep 15, 2014 10:53 AM
BOOSTEd2
13
Mar 28, 2011 04:56 PM
everlight44
Mar 23, 2009 06:18 PM
Camshaft
Jul 31, 2004 10:41 PM
B18C1 '96 Coupe
May 22, 2003 01:37 PM
