gas leak...but from where?
Old Aug 19, 2015 | 07:17 AM
tommy boy2's Avatar
Default gas leak...but from where?
94 civic hatch, can smell it but can't see from where. this actually happened earlier in the spring then it went away. I didn't fill over 1/2 a tank for a while then filled full and it seemed ok- but now its back. how do i find it?
Old Aug 19, 2015 | 07:28 AM
White_EG1's Avatar
Default Re: gas leak...but from where?
I would start at looking for leaks at the fuel tank.
So when you fill more than a half tank do you notice bad mpg? And the smell? If so, I would def look at your tank.
Old Aug 19, 2015 | 07:32 AM
burnoutboy's Avatar
The Credible Hulk
Ignoring a gas leak that "seemed to go away" since spring is probably exactly how the carbecue I saw yesterday started.
Old Aug 19, 2015 | 07:47 AM
White_EG1's Avatar
I did the same thing OP did. Ignored it for atleast 3 months, just got the car and idk but ignoring it seemed like the right thing to do cause I already had a laundry list of repairs I had to do. Let me tell you when I finally looked under the car, I got on my knees and thanked God.
I think it would be appropriate to tell OP dont drive the car until this is fixed.
Old Aug 19, 2015 | 07:49 AM
burnoutboy's Avatar
The Credible Hulk
This is the smartest ******* thing I've EVER seen you say on this website.. EVARRRR!
Old Aug 19, 2015 | 07:50 AM
White_EG1's Avatar
ok
Old Aug 19, 2015 | 02:51 PM
tommy boy2's Avatar
how do i find it? i put some cardboard under the car last night but I worry it has been so hot I think it is evaporating without dripping.
it is a 94 so I think there will be rust all over. But I seem to remember some funky looking stuff near where the fill hits the tank - is this a common spot?
A friend said it could b a pinhole leak and it "self-healed" when a flake in the tank covered it for a while - possible?? thanks
Old Aug 19, 2015 | 02:58 PM
White_EG1's Avatar
Just jack it up from the back tow hook. And look at your fuel tank, if there is a leak it will be very apparent.
Try to park the car in a garage for a couple hours. If its bad you'll smell it.
Old Aug 19, 2015 | 03:24 PM
NotARaCist's Avatar
I never narc'd on nobody!
You can smell it, but are you actually losing gas, or just smelling gas? Is your evap canister still connected? That's the most common cause of a gas smell. Is the CEL on? Does it work?
Old Aug 19, 2015 | 05:35 PM
tommy boy2's Avatar
no CEL on, smells strong sometimes
Old Aug 19, 2015 | 05:40 PM
NotARaCist's Avatar
So check your evap canister, and make sure that it's still there, and the vacuum lines are properly attached.
Old Aug 19, 2015 | 09:57 PM
wk9k's Avatar
You could get some UV DYE from auto parts store and put in your gas tank. Drive a few minutes at night. Then with a UV light check all around the fuel tank..lines and engine. That should help. Or it could be burnt oil that u could be smelling...
Old Sep 3, 2015 | 04:35 PM
tommy boy2's Avatar
i think i found it: looks like the fill metal pipe and smaller pipe are rusty and look a little weepy wet - what now??!
Old Sep 3, 2015 | 07:48 PM
eghatch9295's Avatar
Stancetard Hate Monger
replace it
Old Sep 7, 2015 | 06:35 AM
tommy boy2's Avatar
do i need to drain the tank 1st or just run it so its very very empty?
Also: if these pipes are rusty, what should i be checking on the tank to see if it is still ok? thank you!
Bowl_of_Rice
Feb 27, 2011 06:27 AM
rice a roni
Nov 18, 2005 10:50 AM
E-Rok
Dec 26, 2003 12:55 PM
SjCiViCHB
Feb 14, 2003 06:35 AM
MoBlack
11
Sep 16, 2002 07:34 PM
