Suspension & Brakes Theory, alignment, spring rates....
Koni yellow and gc help
Old Aug 18, 2015 | 04:40 PM
808dc2typer's Avatar
Default Koni yellow and gc help
Have the koni yellow and gc setup, need help figuring it out because I got the gc sleeves and springs from a friend. I tried installing them on my koni yellows and I must've installed them wrong because my car is still at stock height and it's maxed out to the down level. I don't know if I put the springs in the wrong area since they are different heights. I also still have those collars that the springs sit on still I didn't know if those need to come out that's why I left them on. If anyone can help me that would be a big help
Old Aug 18, 2015 | 06:42 PM
Atomic1's Avatar
Default Re: Koni yellow and gc help
Wait, you left the spring perches on the koni yellows?? GC sleeves go on without those perches and bear on the koni circlips.
You may already be aware but worth a mention that you have to use koni specific GC sleeves that have a machined lip that encapsulates the koni circlip....otherwise you risk failing the circlip.
Old Aug 19, 2015 | 12:24 AM
I can't get a pic of my setup till the weekend, but yeah the collars are still on. I didn't check if the sleeves I got have that machined lip. But if I don't have the machines lip does that mean the gc won't work?
Old Aug 19, 2015 | 12:26 AM
Also does the taller springs go in the front or the back? Cause 2 springs are taller than the others
Old Aug 19, 2015 | 03:57 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Did you buy ground controls specifically meant for Koni yellow shocks?
There are about a million pictures and threads on the internet about properly installing these parts.
Old Aug 19, 2015 | 09:59 AM
No I didn't buy them, a friend traded me the sleeves and springs for a hood I had. So I kinda figured it would just fit on my koni's
Old Aug 19, 2015 | 11:14 AM
B serious's Avatar
You can call ground control and get the right sleeves for koni yellows. Its not safe to drive them around sitting on those cups. The cups are meant for springs...not sleeves.
Old Aug 19, 2015 | 06:12 PM
Alright gonna try give them a call. But I think I'm gonna take them apart and see if it has that machine lip first, because it came off another integra but just different struts
Old Aug 19, 2015 | 07:37 PM
B serious's Avatar
Ground control makes Koni yellow specific sleeves. They don't fit any other shocks except Koni yellows.
So even if they have a machined lip...they need to be the right diameter and lip to fit Koni Yellows.
Old Aug 22, 2015 | 08:00 PM
Atomic1's Avatar
x2, if they came from different SHOCKS, then they wont fit koni's properly. IMHO, in the OP's defense, Ground Control does a terrible job showing this distinction on their website.
Old Sep 4, 2015 | 05:05 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You need what is shown in this thread, which also shows the parts you DON'T use with a proper Koni/GC install:
https://honda-tech.com/suspension-br...stall-1212527/
bigmike321321
Suspension & Brakes
Jun 22, 2008 04:10 PM
chris3k
Nov 13, 2007 11:10 AM
Undercover_Skank
Aug 30, 2004 12:55 PM
Myh4tch
21
Jan 20, 2004 04:15 AM
taytay333
Mar 26, 2002 03:54 PM
