p1298
Old Aug 16, 2015 | 03:20 PM
thehondalyfe's Avatar
Default p1298
alright so the ELD high circuit output code is giving me some trouble. I took a multi meter to the green/red to black on the ELD plugin and got no current. so i happened to have an extra complete harness laying around andwent ahead and swapped them out thinking that it was faulty wiring. code still came back. so now im thinking i might have a bad computer? car is a 1998 civic ex with a mini me swap that i did cause when i bought it it had the y7 lx motor in it so i threw a y8 head on changed wiring harness and intake so all was proper. let me know what you guys think. also has correct computer. p2p-a34
Old Aug 17, 2015 | 02:27 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: p1298
https://honda-tech.com/honda-civic-d...8-eld-2515503/
Old Aug 17, 2015 | 12:44 PM
Default Re: p1298
my fuse 15 is not blown. im not pullling any other codes other than p1298, but my dash lights do flicker and speedometer doesnt work. checked the wiring where its said to rub on the intake bracket, and it all looks good.
Old Aug 17, 2015 | 10:41 PM
Alexpro's Avatar
Default Re: p1298
Replace ELD in the fuse box under the hood, see if that helps...
I would do that for the starter, I bet some local junk yard has bunch of civics just waiting for you
Manual says replace ECU if everything else is good...
You can download the service manual from : HONDA CIVIC SERVICE MANUAL Pdf Download.
hope that help any
Old Aug 18, 2015 | 02:18 AM
Default Re: p1298
i did that already. had a spare under hood fuse box from a parts car. threw it it. same result.
thehondalyfe
22
Aug 26, 2015 07:56 PM
KindaRice91
15
May 1, 2013 10:04 AM
RMX_EF9
Aug 26, 2010 09:29 AM
CRXDaddy78155
Sep 4, 2006 05:46 AM
DxBurnoutKing
May 19, 2005 01:12 PM
