Suspension & Brakes Theory, alignment, spring rates....
EG wants to roll out
Old Aug 16, 2015 | 05:30 AM
EGhachiback's Avatar
Default 92 civic: Car wants to roll backwards with e-brake up (Drum Brakes)
My 92 civic wants to roll backwards on a medium incline with the parking brake up, I have to leave it in 1st gear to prevent it from rolling backwards . I've tested this by slightly pushing the clutch in with E-brake up. Do you think my E-brake cable is loose ? brakes ? Help would be greatly appreciated before something drastic happens thank you
Old Aug 16, 2015 | 07:43 AM
phunhaus's Avatar
Default Re: EG wants to roll out
Tighter the nut that hoods the ebrake cable bracket to the ebrake handle. It'll help create more tension on the cables to compensate for worn or slightly stretched cables.
Old Aug 16, 2015 | 07:35 PM
spAdam's Avatar
Loved
Community Favorite
Wait... drums or discs in the rear?
Old Aug 16, 2015 | 09:03 PM
drums
Old Aug 16, 2015 | 09:06 PM
Ok I'll give that a shot after I get off work
Thanks
Old Aug 16, 2015 | 09:16 PM
spAdam's Avatar
Loved
Community Favorite
Originally Posted by EGhachiback
drums
Nothin' wrong with drums aside from not looking as cool. Does the lever go way up?
Make sure the shoes are adjusted properly by turning the click adjusters inside the drums until the they just barely drag on the shoes. The hand lever should go up about 3-5 clicks before it gets tight if you've done this properly.
Edit... a pic:
Old Aug 16, 2015 | 09:27 PM
98civdx's Avatar
Master Detailer
mine did this as well. I tightened the nut on the e brake cables and it was fine.
sL3epy187
Suspension & Brakes
Sep 29, 2008 06:56 PM
broketuner-Sol_Si
May 21, 2006 06:01 PM
sicegcivic
Mar 1, 2006 12:32 PM
Ricey McRicerton
Mar 27, 2004 07:16 AM
gsr96
Dec 11, 2002 08:02 PM
