Which area is 'vacuum part' of the map when tuning ignition
So i'm new to the tuning scene and would like to know which area of the map is the 'vacuum' part? I'm doing research on street tuning ignition and would like to know. Also how do you tune this part on a turbo car on the street? I know dyno is the best place to tune ignition but for knowledge i would like to know. Thanks in advance.
Vac is less than 1000mbar. Over that is pressure.
Ignition is influenced by crank/rod/piston to valve/camshaft timing. Have you modified any of these?
If not, stock timing is fine.
suppose for a turbo car at high speed cruising say you're at 5000 rpm at low load. Wouldn't the turbo be somewhat spooling? And wouldn't i have to reduce stock timing to some extent?
I have a small turbo. Unless you are into the throttle for accel, it won't ride pressure while cruise. No worries.
Timing won't change, just air-fuel ratio.
Within pressure, yes, drop timing, but any tuning program that sets up boost will recommend a retardation policy such as 1degree per psi.
Turbo makes cruise like riding a bike down a slight slope, timing when to push down in the crank rotation won't change, it just won't be trying as hard to pull air into the chambers as it gets stuffed.
There is the issue of increased backpressure and reversion at low loads, but that's another discussion.
slowsleeper
Engine Management and Tuning
Jun 8, 2011 07:00 AM
mrx
May 16, 2005 01:45 AM
