Map sensor please help!
Old Aug 6, 2015 | 03:18 PM
Randyb18's Avatar
Default Map sensor please help!
Im trying to figure out where this connects to any help? And when I unplug the map sensor the car dies, is that normal?
Old Aug 6, 2015 | 03:22 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Map sensor please help!
probably the TPS plug, the map and TPS plugs fit each other you might have them switched.
Old Aug 6, 2015 | 03:26 PM
Randyb18's Avatar
The tps is already connected, but is the car supposed to die if you unplug the map sensor?
Old Aug 6, 2015 | 03:29 PM
wunfstgsr's Avatar
Loved
Community Favorite
Try switching them like i said they both have the same plug, maybe you have the TPS plugged in the map and the map in the TPS.
Old Aug 6, 2015 | 03:31 PM
wunfstgsr's Avatar
Loved
Community Favorite
That other plug thats just sitting there on top of the intake coupler ^^ looks like it might be for the IACV or the IAT sensor on the intake manifold.
Old Aug 6, 2015 | 03:34 PM
Randyb18's Avatar
The tps wire won't reach the map sensor, but can you answer my other question
Old Aug 6, 2015 | 03:52 PM
Randyb18's Avatar
The iacv is connected too?
Old Aug 6, 2015 | 03:57 PM
wunfstgsr's Avatar
Loved
Community Favorite
Ok sometimes the wires are torn from the harness and have more room to move but thats not the case as you say so we can eliminate that. And yes your engine should die with the map disconnected.
Old Aug 6, 2015 | 04:00 PM
wunfstgsr's Avatar
Loved
Community Favorite
on the back of the intake manifold! you can see it on the last pic you posted!!
Old Aug 6, 2015 | 04:01 PM
wunfstgsr's Avatar
Loved
Community Favorite
It should go to that or the IAT sensor. unless its a swapped engine like a ls or C5 swap using a gsr engine harness which leaves a few sensors that are not used.
But is your main problem just figuring out where that plugs too? how does the engine perform?
Old Aug 6, 2015 | 04:08 PM
Randyb18's Avatar
The engine is an ls vtec so yeahl. But It runs fair but like I said it idles really low and dies most of the time. Do you think replacing the map sensor would help?
Old Aug 6, 2015 | 05:20 PM
Randyb18's Avatar
I need help!? My car idles really low and sometimes dies what can this be??? I just replaced the map sensor be cause it was throwing code 3 but seems the same
Old Aug 7, 2015 | 10:56 AM
tamboo's Avatar
10 Year Member
Starting Problems
Old Aug 9, 2015 | 02:16 PM
wunfstgsr's Avatar
Loved
Community Favorite
What ecu are you using or is the engine tuned at all?? or do you have some BS chip setup.
Old Aug 9, 2015 | 02:17 PM
Randyb18's Avatar
Stock p72 ecu and no its no tuned.
Old Aug 9, 2015 | 02:22 PM
Randyb18's Avatar
Stock p72 ecu and no its not tuned.
Old Aug 9, 2015 | 02:23 PM
wunfstgsr's Avatar
Loved
Community Favorite
Get it tuned GEEZE!! and your wondering why it won't idle right...........
Old Aug 9, 2015 | 02:25 PM
Randyb18's Avatar
And that's why it dies?? Why is my cell on for the knock sensor then?
Old Aug 9, 2015 | 02:33 PM
wunfstgsr's Avatar
Loved
Community Favorite
Yes it can very well be the reason in fact i bet you 99.9 % it is.
Your cell is on for the knock sensor cause you probably don't have it connected? i mean is the sensor plugged in? have you even checked?
Get it Tuned and i believe the tuner can eliminate the knock sensor.
Old Aug 9, 2015 | 02:36 PM
Randyb18's Avatar
Yes I have checked and its not connected but like I said before I can't find the plug? And I'm trying to sell it man that's why I don't want to tune it
Old Aug 9, 2015 | 02:42 PM
wunfstgsr's Avatar
Loved
Community Favorite
Try cleaning out the IACV. might help it idle better and not die on you.
Old Aug 9, 2015 | 02:44 PM
Randyb18's Avatar
Alright so the knock sensor has nothing to do with it
Old Aug 9, 2015 | 03:07 PM
wunfstgsr's Avatar
Loved
Community Favorite
https://honda-tech.com/acura-integra...valve-1575913/
https://honda-tech.com/honda-civic-d...22-do-1212895/
https://honda-tech.com/forced-induct...-woot-1181854/
oksblue
Mar 31, 2013 03:59 PM
attica
12
Aug 20, 2009 08:43 AM
D15JDMARIO
Feb 18, 2007 01:52 AM
ZC-EG-6
Aug 24, 2005 10:45 AM
Yellow Dragon
Jul 23, 2003 02:01 PM
