Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
04 civic, strange sound after oil change
Old Jul 31, 2015 | 07:43 AM
nriley19's Avatar
Default 04 civic, strange sound after oil change
Hi everyone,
I just had my oil changed this morning with valvoline 5w20 synthetic. I live down the street from the shop and didnt get to drive it enough to notice at first but after taking it to put some air in the tires, I noticed its making a strange sound right around 2750rpms, like a grinding sound, video will be included, but other than my power steering belt and I believe he told me my alternator belt being slightly cracked, I was given no other red flags. thanks for any input
edit: forgot to add mileage, my car is at 112,320 and here is the link to the sound http://youtu.be/hsypmQyYXhE
again that link is http://youtu.be/hsypmQyYXhE and thanks again for any help yall can provide!!
Old Jul 31, 2015 | 12:04 PM
frisbeeguy's Avatar
Default Re: 04 civic, strange sound after oil change
Have you checked the condition of your ATF fluid?
Old Jul 31, 2015 | 01:33 PM
nriley19's Avatar
Yes and its pink. All of my fluids are fine besides my brake fluid needing flushed
Old Jul 31, 2015 | 02:45 PM
frisbeeguy's Avatar
Check the timing belt and the alternator (a bad bearing can cause that nose). Have one person push the accelerator and have the hood open. Inspect as that person revs the car.
Old Jul 31, 2015 | 03:31 PM
nriley19's Avatar
Will do thanks. My confusion is mainly why would it be making this sound fresh off an oil change? I've never heard this grinding before, and if its an engine bearing wouldnt the fresh oil lube it up? I've read around and have learned the exhaust heat shield could be the problem, possibly a rock rattling around in it, but would that make this type of noise? >
Old Jul 31, 2015 | 05:43 PM
frisbeeguy's Avatar
From that video, it doesn't seem that the exhaust heat shield is the problem. My civic's heat shield did not make that sound (It made a rattling sound). As for why it happened after the oil change, I am not sure. lol. Check the oil dipstick and see if the oil level is correct. If so, then jack up the car and check if the oil filter was installed properly (Remove the engine splash guard).
Old Jul 31, 2015 | 09:27 PM
nriley19's Avatar
Oil level is fine, it's too late for me to jack the car up right now but I'm taking it to the shop tomorrow to see what's going on... I'll let you know what I find out. Thanks for your help
Old Aug 2, 2015 | 08:23 AM
frisbeeguy's Avatar
Ok. No Problem
looopson
May 26, 2011 10:26 PM
zach1288
24
Nov 9, 2006 07:25 PM
eseries07
Sep 27, 2006 11:34 AM
