starter clicks.
Old Jul 30, 2015 | 01:52 PM
onunezp's Avatar
Default starter clicks.
hi fellas,
i have a question, my car is having some problems when i attempt to start it, the starter motor just clicks, ONCE, and its not the battery, i already checked, what can be the issue? brush assy, bendix? can you help me?
94 accord lx, auto.
Old Jul 30, 2015 | 07:33 PM
holmesnmanny's Avatar
Default Re: starter clicks.
google this "larry b's starter contacts" call him, buy some, install them
Old Jul 30, 2015 | 07:50 PM
onunezp's Avatar
thank you, but thats not gonna work for me right now :S im down in Central America, im low on cash and i would like to know what to fix exactly, im going to clean my starter and let ya know whats up
Old Jul 30, 2015 | 09:22 PM
If you take the starter contacts out of your starter, it might be possible to find them at an electrical part store or a supply hardware store.
Old Jul 30, 2015 | 10:04 PM
onunezp's Avatar
are the contacts the same thing as "brushes"? thnk God i have the service manual, thank you holmesnmanny, i needed some direction
Old Jul 30, 2015 | 10:45 PM
We don't have brushes. We have contacts. The next best thing to replacing the contacts is just to take em off and sand em real good til they're shiny again.
Watch that vid and sand up your starter contacts and you might be good to go again.
Old Jul 30, 2015 | 11:10 PM
MAD_MIKE's Avatar
MM Gruppe B
Starter on AT cars is Mitsuba, they do not share the same problems as the Denso starters found on MT cars.
Verify the battery is fully charged and holding a charge.
Verify the battery cables are clean, tight and undamaged.
Verify the ground connections and engine bonding jumper are clean, tight and undamaged.
Verify there is battery voltage at the large starter cable terminal.
Verify the solenoid power from the ignition switch(small wire) is getting battery voltage when key is turned to III(start) position.
Verify the solenoid works but jumping a wire from the small terminal of the starter directly to the (+)positive battery post, or large cable at battery.
#7 is the solenoid on the AT Mitsuba starter, I can't recall if that can be disassembled like the MT Denso starter.
Old Jul 31, 2015 | 12:31 AM
I stand corrected. I somehow missed the part about you having an auto, hence the Mitsuba. I was operating under the assumption you had a manual. Larry had told me before that mistuba starters don't have contacts that can be replaced. I actually havent taken apart a Mistuba starter, even my old auto Toyota camry had a denso starter. You can call him and ask him what your options are for a mitsuba starter.
Old Aug 3, 2015 | 10:48 AM
onunezp's Avatar
update:
thank you both, i checked everything as Mike stated and i dismantled the starter myself and turns out the brushes were very worn changed them and my starter worked like a charm,
* the carbon brushes are the equivalent for contacts in the Mitsuba auto starter for what i can see from Holmesmanny's video and indication,
#6 in the starter diagram provided by MadMike
so thank you, hope this post helps someone in the future.
Old Aug 3, 2015 | 10:28 PM
good deal
StokelesS_g2
Jun 22, 2016 10:48 AM
crazyhouse2011
May 23, 2013 08:23 PM
TheCrimsonGhost666
Feb 28, 2010 06:53 AM
HXvtec
Nov 6, 2004 02:15 PM
Sukebei Oni
Mar 16, 2003 01:21 AM
